  • Replies 55
I used to run Mobil 1.
BUT, just as a treat one day and I liked the name I tried Royal Purple, there is no point in trying to sell it. You just have to try it yourself and see the results. I couldn't believe that oil would make such a difference.
https://www.sau.com.au/forums/topic/14-oils-aint-oils/#findComment-232
  • 3 weeks later...
  Quote
BUT, just as a treat one day and I liked the name I tried Royal Purple, there is no point in trying to sell it. You just have to try it yourself and see the results. I couldn't believe that oil would make such a difference.[/quote:fd1587d658]
i've heard nothing but praise about the royal purple. it's on everyones top list so it must be worth it. i think i'll try it in around 2000k's when my service is due.
peakRPM, how much do you pay for 5L?
https://www.sau.com.au/forums/topic/14-oils-aint-oils/#findComment-233
There are about 3 different "grades" of Mobil 1. I'm not talking about the viscosity but the actual quality.
This was news to me a couple of weeks ago. I have been using the 0W40 I get from my Bro in law. Cost price is now $16/litre, used to be around $10. It's good stuff. It's not the same as the stuff you get at K-Mart.
The car blew some tiny puffs of smoke when it 1st went in but now doesn't blow/use any. Thin as water. I change it every 5000 or earlier (usually 'cos I can't quite remember when 5000 is up...)
Recommend it.
https://www.sau.com.au/forums/topic/14-oils-aint-oils/#findComment-234
In an engine like the RB25DET I think the thinner the better. Nissan engines typically use a fairly thin oil anyway (normally around a 5W I think). Their tolerances seem pretty tight, so the thinner the better especially with the turbo.
In the bike I use a thicker oil (straight 40W or 50W) as it's air cooled and these engines naturally have wider tollerances. If you have an old clunker and it's using/blowing oil try a thicker viscosity.
Whatever you do keep that el Cheapo no name stuff out of your engine. Buy the best you can afford.
https://www.sau.com.au/forums/topic/14-oils-aint-oils/#findComment-238
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
