  • Replies 55
I used to run Mobil 1.
BUT, just as a treat one day and I liked the name I tried Royal Purple, there is no point in trying to sell it. You just have to try it yourself and see the results. I couldn't believe that oil would make such a difference.
https://www.sau.com.au/forums/topic/14-oils-aint-oils/#findComment-232
  • 3 weeks later...
BUT, just as a treat one day and I liked the name I tried Royal Purple, there is no point in trying to sell it. You just have to try it yourself and see the results. I couldn't believe that oil would make such a difference.[/quote:fd1587d658]
i've heard nothing but praise about the royal purple. it's on everyones top list so it must be worth it. i think i'll try it in around 2000k's when my service is due.
peakRPM, how much do you pay for 5L?
https://www.sau.com.au/forums/topic/14-oils-aint-oils/#findComment-233
There are about 3 different "grades" of Mobil 1. I'm not talking about the viscosity but the actual quality.
This was news to me a couple of weeks ago. I have been using the 0W40 I get from my Bro in law. Cost price is now $16/litre, used to be around $10. It's good stuff. It's not the same as the stuff you get at K-Mart.
The car blew some tiny puffs of smoke when it 1st went in but now doesn't blow/use any. Thin as water. I change it every 5000 or earlier (usually 'cos I can't quite remember when 5000 is up...)
Recommend it.
https://www.sau.com.au/forums/topic/14-oils-aint-oils/#findComment-234
In an engine like the RB25DET I think the thinner the better. Nissan engines typically use a fairly thin oil anyway (normally around a 5W I think). Their tolerances seem pretty tight, so the thinner the better especially with the turbo.
In the bike I use a thicker oil (straight 40W or 50W) as it's air cooled and these engines naturally have wider tollerances. If you have an old clunker and it's using/blowing oil try a thicker viscosity.
Whatever you do keep that el Cheapo no name stuff out of your engine. Buy the best you can afford.
https://www.sau.com.au/forums/topic/14-oils-aint-oils/#findComment-238
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
