My Restoration
Ok. Thing is, its all still shimmed as it was before and nothing much has changed, just all new seals and bearings. Will it need to be re-shimmed? I was hoping just to check the teeth contact areas and if they were still ok to put it back together like that. Another thing, I didnt mark the pinion companion flange before removing it from the pinion shaft. Later i realised i should have, however it doesnt mention to do that in the manual and it normally would if at all necessary. Do you think it needs to be in a special way? Its not a master spline so there is many different ways it can be put it. What do i do?
Im getting a pair of Garrett 707160-5005 turbos this week coming! That will be exciting. This weekend i purchased a 2nd hand Trust oil cooler and filter relocator locally in Brisbane off 17SOK. Thanks to him for that. I need some help with the proper mounting of the core. Im not sure where exactly its meant to go behind the right hand duct. Ive got one friend getting me pics but if anyone else has one setup like that id appreciate a few more pics.
Deren
Turbos should have arrived by now?
I like reading the updates in this thread ;)
Hey mate!
Turbos arrived a couple of days ago. I ended up buying them off Chris Whittaker at MTQ Salibury here in Brisbane. I throughly recommend giving him a call if you need to purchase some new turbos as he was excellent to deal with and gave me by far the cheapest price! :(
I have added some new pics of the turbos including new vs old. Shows the difference quite well.
Before i fit the new turbos i will need to save up (now broke) for the stainless CES long front/dump pipes i have had my eye on :D As i will need to fit the first section to the back of the turbines before mounting them to the manifolds etc. Not much has been done to my GTR as i have been getting my daily (shitter) ready for the road. Its a 87 mitsubishi magna TN. Its hard to believe that these two cars were designed in the same era! I guess one being worth over 100 grand and the other being a run of the mill family car would have something to do with it. Since i took the GTR off the road (2+ years) i have had no car to drive so it will be nice to have a car to run around in!
Deren
Edited by Godzilla32
Good news on the daily driver!
Now that your GTR doesnt have to be daily driven though, you may find yourself thinking of other things you can do to it :)
What are those CES pipes worth roughly?
wow, sure those turbo's are going to pack some serious horse power! have to come around n have a geez soon. can't wait to see this thing fly! speak soon deren, cheers, hame
Deren
the 2 mounts on the left are using existing threads on the body
this mount goes to a hole behind the radiator overflow bottle u will need a screw, nut and washers.
mounted oil cooler.
cut hole for vent.
vent siliconed and rivited in place. though self tapping screws would be better as the rivets will stretch the plastic.
i made a duct out of template plastic. when finished make sure you cut at least 1-2cm back from the oil cooler. you
dont want it rubbing on it. i also used race tape to connect and hold either end. but the basic box is held together with self tappers.
underneath.
through front bar.
Looking good Deren.
Have you thought of getting stainless manifolds and dumps?
There are horror stories about poor quality stuff but I bought the dumps from Ebay and did a little work to get them as I wanted (some finishing with the die grinder to get the transitions smoothed nicely and dress some welds), and the manifolds I got from a forum member cheap as they needed to be skimmed flat. Almost 18 months making 320rwkw with no dramas at all. No cracks or leaks. Most problems are with one piece single manifolds warping but less chance with 2 piece for twins.
The big difference has been the extra power came easy. Same boost, 14psi, and an extra 70rwkw using highflows. The boost comes on much faster as well. Soon to retune to 18 or 20 psi to see how it will go.
    • Meh, maybe the JSAI ones are FG not CF. But, given that I'm not convinced any of these look any good, it hardly matters.
    • Got them in the other day. I can confirm the r33/r34 nozzles (B8K30-AA000) are the exact same. Hope this helps anyone else that comes looking for it
    • Yeah, I should state I have no overheating issues except when it's sitting idle, with AC on (and only then) and only on VERY VERY hot days. And it stops if I turn the AC off. But I put a lot of effort into making this thing run like a regular car, I want the AC to work when I want it to work. I need no excuses as to why I should make some other thing a daily! And tbf, the thing does heat soak pretty bad, not much I can do with the exhaust running under the driver's seat, you can feel it through your shoes/pants when you step out of the car, too. Point being, aircon inside the cabin is on pretty frequently. I did think about removing heater hoses to simplify the engine bay/back of engine because I cannot imagine a scenario where I ever need a heater. Except for defogging, but doesn't AC do that, not the heater? So in this very limited situation, raising the rear could work, purely to let hot air out. I've ran the car at the track on a 35C day with the aircon on, and it doesn't overheat in that scenario so that's why I thought it was due to heat soak/heat buildup and not just general overheating under load. I had previously tried shrouding the radiator, changing my balancer to a non-underdriven one to spin the water pump more at idle too, and installing two more thermo fans on the other side of the radiator/AC condenser. (So I have 4 now, 2 pushing, 2 pulling from the rad) neither really helped in this very limited scenario. I don't know if the vents will, but visually seeing the heat steaming out of them did give me hope, not to mention the temperature of the vents was MUCH hotter than other areas of the bonnet. Enough that one of the paint guys was unsure as to whether paint would stick to it long term. I'm sure that will be fine also.
    • JustJap sell CF underskirts like that.
    • Its been a while since the last update, I've been collecting parts to overhaul the suspension - Most of the bits have arrived, theres still a few bits to come in the next few weeks and still to order I started by overhauling the ATTESA unit   I stripped it down, Cleaned the main unit and replaced all O-rings, bolts, Accumulator, Pressure Switch and painted a few bits   And done!   For anyone swapping the accumulator, a 3-inch socket makes life a hell of a lot easier   And a big pile of parts ready to go on, with more still to come over the next few weeks 😐
