man this is insane i just got my car a few days ago and plan on slowing cleaning and fixing everything. with your bay do you plan on hiding wires and reloctating the battery etc. im thinking about doing this. ps very nice build.
Cheers mate. I had thought about hiding the wiring etc but looked back on original photos and realised that with everything back in the engine bay you can't see much of the wiring anyway so it would be a bit pointless.
Im currently getting the block painted up and will either assemble the bottom end this weekend if its raining or if not, i'll head out to jamboree at willowbank :P
More to come soon..
Deren
The brakes? They are all original. I machined the rotors all round. Scuffed all the pads (save money). Carefully painted the calipers/rotors and filed back the logos. If you want new brakes go aftermarket. Nissan wont be cheap!
Hey, sorry for the long delay between posts. I was struggling to get a piston ring filer at first but now its pretty much done so i'll be assembling the bottom end with GTRgeoff tomorrow.
Posted pics of:
Forged pistons
ARP rods bolts
Forged conrods
Linished crank fitted with Jun crank collar
Block on stand
New main and big end bearings
Deren
Ok finally the bottom end is together. Today me and GTRgeoff assembled the crank, rods and pistons. So basically i now have a freely rotating bottom end minus all the extras like oil and water pumps, head, sump, turbos etc.
Here are a few pics of me and Geoff bolting it together.
This week i'll be picking up my sump and cylinder head from JHH engineering. John at JHH has port matched the head and done the chambers. Down in Melbourne the head has also been fitted with all new guides, stem seals, pocket flowed, re-shimmed.
JHH also setup an external oil return, its tapped into the back of the head and the side of the deep section of the sump (where the pick-up is). I've had the drillings in the sump opened up too, where the oil makes it way back to the deep section if it returns through the block.
Now i just need to get myself a Tomei sump baffle and a new head gasket, possbily Cometic. Then i can bolt them both back on.
Im also going to get John at JHH to check over my throttle bodies, as since i cleaned them i've always had an annoying high idle due to air leaks.
Planning to order a pair of 2860-5's in the next few weeks :thumbsup:
Deren
bloody hell.....geoff helped? you could be in trouble :thumbsup:
re the throttle bodies - cleaning them is a no-no, they have a coating on them that is easily removed :down: Your best bet will be to get a second hand set of throttle bodies. Will be interested to see if JHH have a solution
Yeah i know, Geoff is a worry. Haha, he will know what i mean.
In regards to the throttles, i've already spent a bit of cash on them trying to sort them out but i think i was ripped off by a failing business. John said he does alot of throttle work so im pretty confident he'll be able to help me out :thumbsup:
Cheers,
Deren
re the throttle bodies - cleaning them is a no-no, they have a coating on them that is easily removed ;) Your best bet will be to get a second hand set of throttle bodies. Will be interested to see if JHH have a solution
So what is this coating? what does it do? and what happens if it is removed?
Let's just say never leave a dodgy bottle of Wurth thread locker sitting next to the assembly lube ;)
There is no substitute. Only ever use Loctite!!
And bugger assembly lube. Lanox spray is a million times better.
Having now had the grand tour of the work Deran has done in restoring this machine, all I can say is all the old busted arse 32 GTR's out there are not even in the same league, even if perfectly new from factory. The colour is magnificent and the attention to detail is beyond any but the finest auto manufacturers.
Consider the spray job inside and out, the underbody sealer, the colour matching on items as simple as the steering rack....... the list goes on.
If he ever drives it it will be a travesty.
Also the TB's need to be sealed or you can't get a low idle. 6 TB's let so much air through compared to one so cleaning them is a no-no.
John from JHH engineering that machined the engine for me said that the block and all internals should have been throughly washed out prior to assembly. I kind of felt like this would have been a good idea. He said to make sure it is all completely spotless. Another thing he said was not to oil the pistons, but only smear a little on the piston skirts. He said use something like CRC to prevent the bores from rusting but nothing else. The reason being is that it improves ring bed in and apparently this was discovered about 15 years ago. I found it hard to believe but other people have also confirmed that its the correct way for a quick efficient bed in. He also said there is no harm in re-using the same bearings, torqueing down the internals to check for clearances is the same procedure. I have spent thousands on this engine and groud up rebuild, i can't take any risks on any part of it especially the engine. You can call me obsessive but its better to be careful than to be careless and have something fail and waste all that time and money. The way i see it is John has machined this engine and has done so for a very long time (30+ years) and sticking to his guidelines will mean if anything does go wrong my method of assembly can't be blamed.
However don't get me wrong i was very appreciative of your help Geoff, i'd just prefer to be safe than sorry when so much money is involved.
Deren
You're all good Deren. You have to be happy with what you are doing.
I just recently read an ACL based document on the washing of the bores and block, which I get done at the machinists anyway ready for the final build clean. As I've mentioned there are so many different opinions out there, and I stick with what works for me. As you saw, when I deviated from my process things got interesting.
Have fun mate. This is the good part.
yeh wen i rebuilt my gze and i got it back from the machine shop, prior to assembly i went and got two rolls of paper towel wax and grease remover and about 5 cans of degreaser, i degreased the block down about 10 times and wiped it down with white paper down each time to the point that if i wiped the block with the white towel i wouldnt get any dirty marks, it would be spotless... took a while but its a satisfactory thing its clean i guess :domokun:
i found also dont forget to give your fly and clutch a nice wipe down as even when i did mine i still found it sliped a bit even after it was run in. tis ok now tho
Edited by BANGN
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
