  • Replies 65
  • 3 weeks later...
Well looks like I'm going have to get kicked out of here... I just cant seem to find the car I was looking for and while I was looking for my new car I ran across this.
imgfree.net - Image Hosting
I had to sell mine when I came here to Oz. Dont regret it one bit I have a wonderful wife and boy on the way *fingers crossed*.
So for what I was looking to spend I just going to jump on this since not too many here to get.
Got some great info here I just want to thank all those that helped
Rex
Edited by Rexx
Might be able to stretch for something like...
Audi S4 biturbo
Audi S8
E36 BMW M3
Volkwagen Golf GTi
have to say AUDI B5 S4 twinturbo is on the top of my list, kinda like the german built luxury version of GTR, much potential: tough 2.7l V6 TT, strong 6 six speed, 4wd and at $40k! what more could you ask for.
dont get anything german!!!! great cars if u can afford the service and maintainance!!! and if ur planning on modding it, tuners will charge u through the roof!!! besides the things are just boring, u pop the bonnet and all u see is f*kn plastic covers, f*k that shit.... R33 GTR or JZX100 CHASER, and thats a NUTS chaser... not too mention 1JZ motor can handle shit loads of pwr!!!!! evos are cool but at the end of the day they are lancers!!! f*k that shit too... hope that helps buddy...
cheers jure
I concur with the Chaser. Awesome car, only like the JZX100's though. For a 4 door semi-luxo model they weigh in at about 1480kg and you can get them with the 1JZGTE single turbo VVTi and a 5spd.. can't go wrong! Probably be my next car.. for the missus to drive :)
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
