  • Replies 76
Posted Images
Hey Greg,
Well that’s pretty silly paint lol, I wonder why they would bother putting it on then? anyway, I’ll be getting a set of these, how would i go about getting the paint off?
What are the downsides to not heat wrapping them? just a hotter engine bay or will other things go wrong?
I am still a bit hesitant about heat wrapping mine because I heard that you can do damage too them when they don't cool down quick enough. Have you come across any of these problems?
ohh and what heat wrap did you use?
Thanks mate,
Regards,
Sean'O
i didnt really think heat was such a big issue with headers, obviously the engine bay is a little warmer, and you might get a cool orange glow if you give it enough stick - but since headers deal with exhaust gases and the gases are constantly being expelled i cant see any sort of large significant gain.
although someone can come tell me otherwise, i'd like to know as well.
Hmm, well that all looks very pretty but, it sounds very expensive and in my case a bit unnecessary,
I only have a RB20DE, and its not a dragster lol, so I don't think I will need the heat protection presuming that the extra heat by just having them in there won't damage anything during everyday driving.
However I would like the corrosion protection to make them last a bit longer, wouldn't the caliper paint (as suggested above) be sufficient here?
What we need here is an opinion by somebody who installs exhausts, or someone who has had this particular unit for a while.
I'm still assuming that the level of heat protection etc is dependant upon the style of driving your car goes through, if you just drive to work and back I would guess that ceramic coating is a bit extreme, but if you do track work or something, maybe its worth it.
Again I’m just prating on, we really need some guidance here,
Regards,
Sean'O
The bottom of my intake pipe started to melt from the high temperatures. This could have caused a fire and ultimate destruction of engine. This, and the power gains, is why I recommend to heat wrap them. Having said this there are plenty of people using them un heat wrapped without dramas
The orange paint is just to stop them rusting while they're in the shop etc. so they look good.
You could use a blowtorch to get the paint off, or paint stripper, or just heat wrap over it, won't be the end of the world.
Cheers
Greg
thanks for your input greg, much appreciate it...
guys please check the group buy thread, i have updated the first post accordingly - and will need each one of you to state what it is exactly that you want. then we can finalize prices.
see here:
http://www.skylinesaustralia.com/forums/in...howtopic=140134
i'm getting a 2.5" outlet, gasket, hpc coated with economy delivery and it's totaled to AUD$425 which is an absolute steal!!!
guys, some good news... i've called up and we are pretty much good to go.
- they are able to cut the outlet back to 2.25 to 2.50", since i know most of you would have/looking into a catback system in future.
- hpc coating is AUD$170 per header.
- i've also made mention about the orange paint and they are looking into that, obviously not a worry with HPC coating.
- i've also made arrangements for a variety of shipment, these will go from them straight to your door.
- rb30e extractor is also available (the code is D5) and i have sweet talked them into including that into the arranged price with rb20/25.
shipment options
International Express (1-3 days) AUD$100.00
International Air (3-6 days) AUD$70.00
International Economy ( 10-15 days) AUD$60.00
http://www.skylinesaustralia.com/forums/in...t&p=2659059
another update guys... please check the first post of the group buy thread - make sure everything adds up accordingly and is correct.
confirm with me and i'll provide you with bank details.
cheers
Well just got myself one... Can't wait to hear the extractors on my r34... It already sound rippy... imagine with extractors and 2.5' exhaust mmm =]~. Oh also If you guys are to get one or anything from eug. do so he makes things so easy ^_^ and obviously well trusted! Cheers eug again.
Edited by Specrzx
you should receive yours well before anybody else buddy, since you have air freight and are not waiting on hpc coating.
check the link in my sig to check the group buy thread for updates.
according to the email i recieved yours was sent out on the 29th of november so give it 3-6 working days... expect them around the end of the coming week, or beginning of the week after. let me know otherwise.
please be patient, this stuff is coming internationally
  • 3 weeks later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
