Can anyone tell me if there is a limit as to how many cars i could import to australia from new zealand as private imports?
Also can i bring cars like WRX, CRX(2nd and 3rd gen VTEC) under private since they were sold here?
I am planning to move to new zealand soon and would like to bring a couple of cars back for myself and to sell to friends once i have them here.
PS: i understand that the rules may change before i am ready to move back but i am just looking for an idea.
Thanks.
https://www.sau.com.au/forums/topic/140120-importing-from-nz/
Thanks.
You can import any make or model as a personal import as long as you are moving back to Australia to live here again, you also must have owned and used the car yourself for the full 12 months - evidence would be required that you are not just coming back for a holiday and that you have had the car long enough.
Thanks for the answers guys :( i also wanted to ask what if say, a person came over to australia from nz and brought their own car could they sell it while here?
Depends on a whole number of things. Best you check with NZ Customs.
  • 1 month later...
My Dads moving here to live next year (for good) and was going to buy a Forester STi before the move and wont be waiting long enough for it to be 12 months of ownership... he knows he isnt going to be able to get one here so he wants to buy one and bring it over with him
From what I understand, he will need to have ownership documents, rego papers, fuel and service receipts dated at least 12 months prior to export for the vehicle to be brought in to Oz as a private import.
If he hasn't then it can only enter the country as a race import and he will need a CAMS licence for that.
Given that the NZ prices are dirt cheap, it might be worth forgeting about the STi Forester and buying something that can be complianced here like a Legnum or Aristo. Still potentially cheaper than buying from Japan, plus he test drive and have the vehicle inspected in NZ.
If he cant bring anything over as a personal import he wont bother.
Although i might be able to convince him to buy an R34 GTR and bring that over and sell it off... Is that possible? Can he import one of them from NZ?
Maybe something like this
http://www.trademe.co.nz/Trade-Me-Motors/C...on-81785403.htm
or maybe something more std and easy to comply like this
http://www.trademe.co.nz/Browse/Listing.as...69&key=7479
  • 3 weeks later...
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 12 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
