"i dont wanna have to make it a Nissan Highline just to get it past the pits tho."
you dont want to but if u want to pass u mite have too.. part and parcel of owning a hpi. do wat you gotta do, hell return it to dead stock if u have too den go to welshpool or o'connor/myaree and pass first time. saves u grief.
like dey say do it once do it right.
here's another thing. suck up. do wat dey say dont argue and for ffs dont b cocky and think ur all dat. dey deal with this shit everyday, and to them ur another one.
just my 2c. (yes, i frequent the pits a hell of alot)
  • Replies 66
Posted Images
i dont get it? how does having faded/silver windscreen wipers make your vehicle unroadworthy? thats the biggest load of shit ever :S
Its called ADRs, wipers etc should be non reflective - you cant beat adrs, unless you get an engineers report.
100mm is legal, I actually passed my car over welshpool pits slightly lower than 100mm (ie, it scraped when it went over) but the guy there thought it was close enough and let it slide
I also passed welshpool with coilovers - I really dont trust outstation pits, unless its pretty much stock, they dont like passing anything.
We have had to change the same bushes on a car 3 times. Then after telling us what a POS it is, he could only find 1 door handle you had to fiddle with to get open. If they don't want to pass you, they will find something.
Pit day 2 = ARGH!
Failed. again. Nothng mentiond about the previous problems. Now my front indicators are 2 far in, and not high enough. So looks like im in shopping for a new front body kit :)
Did you go to welshpool? Those reasons are BS. What bodykit do you have?
Aye i went to Welshpool. A 32 was in front of me.. got a little asian guy inspector, passed him after like a 5 min expection. I was like pleeeeeeaseeee give me him, he probaly owned the GTR i saw in the parking lot :) Then i saw the inspector from kelmscott come out and im like ohhhh shit! I had my friends mum take my car thru, and lucky he went to some other guy instead of to me... then the asian inspector waved my friends mum to come forward so i watched from the seats at the side. Went around all the outside of the car and checked all the lights horn etc. He stopped at the front of the car and looked at my indicators and is like to the guy that failed me the first time (the old kelmscott guy).. they look okay to you? and of course he said no. i was like GRRR so i ran over and asked what the problem was. He explained my lights were to far down and to far away from the outside of the car. He also said that if my headlight indicators were working it wouldnt matter. I then told him that R33 indicators are not apart of the headlights and they are below the lights on the body kit. He just said it dont meet standards, and failed my car ;)
So ive done a bit of looking around on SAU and ive found a number for a panel beater so im gonna go in tomorrow and get a quote.
here's pic sorry about quality.
heys, dat was me in the skyline (if it was a white one, and if your 33 had a black fmic). the 5 minute job was a re-inspection.
btw on a side note wat colour was the gtr in the car park? i didnt c one...
We got told off for having 8 1/2 inch rims on a Commodore (back in Trev days) but then if it was a "HSV" or "SS" it would have been ok but it wasn't. Doesn't matter that they are exactly the same under there.
Then had tail lights checked on a 31 "they were too dull" but then next inspection I said "checked by an auto sparky and said they were normal" and the inspector says "oh they are fine". Grrr....
Can see why people get annoyed.
indicators are to be within 400mm of the side of the car i think..
i have a very similar model bar to yours, and this is where mine are mounted.
(in the right/left hand vents, up the top)
ADR 13/00 INSTALLATION OF LIGHTING
front direction indicators
no more than 400mm inboard of vehicle outer edge
at least 600mm apart
between 350 & 1500mm above the ground
visible 45 deg inward & 45 deg outward
visible 15 deg upwards & 15 deg downwards
(dont look at my front bar lol)
vehicles are not supposed to have any variation to running gear from what came from factory with out engineers report
does not matter if the cars are identical , if the factory did not fit it then they can knock it back
Ive never been over the pits, but some of the reasons they give are just total BS. Things that affect car safety, ok, but indicators too far in, what the f**k does that even mean from a car owners POV? isnt that where the manufacturer put them?
these aftermarket front bars are made for looks only
the reasons are BS but the line needs to be draw somewhere
there are enough bad drivers out there that dont need any help from poorly designed body kits making it harder to see the safty equipment (thats what these lights are) than they need be
IMO
not quite, new federal standards allow quite significant variation in wheels sizes and also allow for variation of track up to +25mm without engineer certification.
My 17x9x10 inch rims passed over welshpool on an S13, and yes they did measure the wheels, check track, and check tyre size - all legal.
there are lots of changes to federal stds going on all the time
the problem is that the state authorities dont always know there has been a change unless someone informs them
also the guys at licensing dont know all the adr's and vsb's that are being developed, if you are aware of some change but you still get knocked back, its probebly because they are unaware and you need to inform the top bloke there (John Dombrose) of any changes to the regulations.
also comes down to the individual checking the vehicle, and he can knock it back for any reason he wants
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
