Hey
I'm going on a short holiday soon to Japan.
I want to visit some car part shops to buy a few things but I am struggling to find any info on the net. I know there are going to be a heap over there but I want to make sure they are close by and easy to find from where I am staying.
So, does anyone have any links for car part shops? Looking at buying my turbo's, cams, injectors and some other things. I am specifically after HKS and Nismo items.
Thanks
https://www.sau.com.au/forums/topic/140214-car-parts-shops-in-japan/
Autobacs is your friend. its like a Bunnings Warehouse for cars
Aisles of air fresheners
Aisles of wheels
Aisles of air suspension
Aisles of mobile phone holders
Aisles of turbos
Aisles of everything.
im hopefully going over next year
They are starting to open up a few secondhand Autobacs Stores. selling nothing but secondhand car parts and performance bits, wheels, suspension, etc, would be interesting to see.
Akihabara--are there any tuner shops there? It seems like a lot of the ones I've seen in Tokyo are fairly scattered about. More or less, you'll just be walking down a busy street and you'll see a smaller tuner shop with a bunch of tuner cars in front.
In terms of finding everything in one place, Autobacs is good but Super Autobacs is even better. I think there are a fair number of them in the Tokyo area, although I don't know the exact locations--try their website or the internet.
Otherwise, a good thing I've always done in the past, especially if you're looking for parts for a certain car, is to go to a specialist tuner shop so they'll know exactly what you're looking for. I've found a lot of these places are listed in the Hyper Rev magazines that come out periodically for certain types of vehicles (they should have tons of issues for the Skyline).
Good luck!
Aisles of wheels
Aisles of turbos
Not having a dig, but have you even been to an Autobacs? They are nothing like you mentioned above.
Extremely limited range, very small amounts of real performance parts and ultra expensive prices.
[200]: Keep in mind that you will most likely have to order the majority of the parts on your list as even the good parts shops often wont have everything you need in stock ready to go.
If you can head to Chiba, there is a new parts store close by called Crystal that I rate as the best in Japan for both range and prices, and if you need anything they dont have in stock, they are more than happy to order it for you.
Top Secret is also down the road and there is a decent Up Garage close by as well.
Autobacs "performance" aisles... yeah thats a joke. The "performance" parts are usually a couple of short aisles of STi stickers with an intercooler or two on display mostly for current models which are of no interest to skyline people.
Upstairs at Tokyo bay Autobacs sells some nice hotdogs and some kinda ok back issues of popular magazines like GT-R magazine. As well as a small collection of overpriced dealership catalog/brochures which is of some interest but I think I bought them out of GTR stuff a couple years back.
I would avoid autobacs really - or visit Tokyo Bay or Chiba Naganuma at the very most unless you love wandering down countless aisles of Hello Kitty air freshners and pink seat covers for your Toyota Hiace SuperComfort 4x4 turbo deluxe.
is crystal only in chiba or all over japan?
what they said about autobacs is correct... but if you want a cool cup holder then by all means got to one...
upgarage has the best prices on parts... used ofcourse but still good.. there pretty descent for wheels...
anything you want new u can order from a shop it will only take a day or two to arrive so thats not to bad...
  • 1 year later...
  • 3 years later...
Guys Has anyone got any updates as i'm going in 2 months and of course i'd like to come back with a bunch of goodies.
I'm flying into Tokyo and will also be around Osaka at some point, i do have some time and money to spend.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
