ok, so I am days away from getting the drivers side (already have the pass side) N1 light and will be jamming them in asap... but I have heard the wiring is different?
Has ne1 here had experience with these headlights and the wiring? Beta still, has ne1 got a set ...
mmm that sounded bad?
https://www.sau.com.au/forums/topic/140219-r32-gtr-n1-headlights/
use to have those type of lights on my GTS-t only difference i have found that you have fog lights on them. think you might need extra wiring for that not sure.
well there is the factory fog light switch on the dash just above the headlight switch so maybe the wiring is already there *crosses fingers*
is that what the 2nd filament is for on the high beam?
you say you used to have them...can I ask why you changed them? and how did you get them to fit on a gtst when they are for a gtr?
i would say the single light is the fog light and the h4 dual filament globe would be the hi/low beam in one as it is on most other cars
sounds like a winner!
I have seen another 32R for sale that had these light and only the single light (closest to the grille) was on, and a pic I took of a R32 Vspec N1 on GT4 has the headlight as the larger light... F*$k I sound like a geek taking that much antention to the GT4 car!
The freight company has said the package will arrive tomorrow so this weekend I should be on the tools getting them in and wired correctly...
I'll post some pics
Thanks for the help guys
looks like the ones on mine and my bro's car.
the "small" square light is h3c and thats your foggies. the big rectangular one is your normal driving lights. its where ur park lights are also. they are h4 and t10 for parks.
hope that helps.
Well the other headlight arrived and so today after lunch I hit the tools.
The swap over took about 1hr-1.5hrs and was a very easy task...
1)remove centre grille (5 clips)
2)remove outside indicators (1 screw)
3)remove headlights and associated wiring (4bolts + couple of plugs)
4)install new headlights
5)replace outside insicators
6)replace centre grille
The passenger side bottom bolt was a tricky one to get to so I just removed part of the intercooler piping for better access. The pod filters have to be removed first for any room to move and the same on the drivers side... the battery was given the boot while getting down and dirty. The bottom bolt on the drivers side was also a little crammed as some pipes (I think air con) were in the way. Socket with a swivel section just to loosen it and then it was easy to undo by hand.
I am still yet to finish the wiring as there are plugs for the fog lights but the switch on the dash has no plug connecting it??? I will check this out tomorrow or one of the next couple of weekends so I can get these working... I'll update this thread then.
Personally I think the car looks much tougher with these lights as it suits the rest of the N1 body kit (bonnet lip, side skirts and boot lid lip)... just need to get the special "no rear windscreen wiper" rear window for the authentic look!!!
Managed to find some time today to get the instrument cluster out so I could look for fog light wiring... and what do you know... there is a standard plug and wiring loom already there taped to the rear demister loom!
simply pluged the loom into the existing fog light switch, checked the fuse was ok and flicked the switch... let there be light. The fog lights run off the battery and not accessories like the normal headlights. The odd thing is though... the park lights also turn on with the fog lights? I didn't notice the rear lights on but I will check it out and post some pics of the now finished job.
Hope this thread helps anyone thinking about changing lights or hooking up fog lights? I would suppose you could use the factory switch and plugs near the bumper to add aftermarket lights (like the very common PIAA spotties on a heap of imports)...save you a bit of time with wiring?
so are you selling you head lights now??
Yeh but I already have someone who has been waiting a while to take them... maybe I should run an auction!!! The price atm is $195 for the pair (which I think is a bargin as most lights are around that price each not a pair)... they will be gone by Thursday if noone else wants them?
Sorry I know this isn't the 4sale section, but had no intention to try and sell these lights through this thread... just PM me if your interested.
  • 3 weeks later...
There has been a problem with the passenger side headlight not working on low beam and the parklight working only intermitnantly. After checking it out my self, tracing all the wires from the headlight plug, under the radiator support, etc... the wire was still dead.
I took it to a sparky today for a fix. He said the plug at the actual switch on the dash cluster was where the problem was. When I was hooking up the fog lights it was easily visible that the main headlight plug was burnt from too much current, however a friend who has seen this before had told me that it's the same on all R32's. It looks like when it burnt out it still had connection, but when it was unplugged it lost it's connection.
if you get the same problem... check there 1st!
By the way, my old lights are gone
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
