I'm considering buying this one but from what I can see it only has one inlet and a breather to vent to the engine bay, thus making it as illegal as my current cheapass crankcase breather.
Autospeed have an article somewhere on how to make your own, should cost less than $50 but doesn't look as good as the above one.
https://www.sau.com.au/forums/topic/14022-oilair-seperator/#findComment-281045
A catch can or oil/air seperator will also prevent oil vapour from coating the inside of the coola - this will reduce the coola's efficiency. When I got a front mount, i noticed that the inlet side of the stock one had a black film on it - not good.
MIght be worth considering too, that if you fit a catch can that vents to amosphere (rather than plumbing back) it is illegal from an emissions point of view.
https://www.sau.com.au/forums/topic/14022-oilair-seperator/#findComment-282083
  • 1 month later...
Might be worth considering too, that if you fit a catch can that vents to amosphere (rather than plumbing back) it is illegal from an emissions point of view.
Bang on.
As well as being illegal, it will also make your car smell like a 1970 HQ Kingswood which is not very pleasent.
in terms of catch cans what is too loook out for.
does size matter with them, or is it all in the design
They are simple in operation and will have two connections, think of it as "line in" and "line out". For it to be effective there will have to be adequate baffling in between these lines, otherwise the same oil you are collecting will find its way into your inlet.
Do a search on Autospeed and you will come across articles like this one which will explain it better.
https://www.sau.com.au/forums/topic/14022-oilair-seperator/#findComment-347121
From the ease of maintanance point of view, bigger the unit better it is. The bigger units would also work more effectively as well, depending on what you do with your car. The downside however is the difficulty in finding a proper spot for a big catch can.
ARC make an awesome one that replaces your windscreen washer bottle, but they are quite expensive. Getting a custom one made on the same principle would be a lot cheaper and should be looked at.
https://www.sau.com.au/forums/topic/14022-oilair-seperator/#findComment-347177
  • 3 years later...
The idea behind the seperator is to remove oil fumes and vapour from the air (blow by) from the crankcase before it re-enters the engine to be burnt. In order to get the seperator to work to its best, it needs to do a few key things.
1. The seperator needs to be of large enough internal volume to slow the air stream which is laced with the oil fumes. The slower air means that there is enough time for the larger oil fumes to 'stick' to something and create a droplet. These droplets help 'grab' smaller droplets and removes lots more oil.
2. The seperator needs to have a massive amount of internal surface area. Buffles are not usually good enough to 'scub' the oil from the air. It is recomended that the seperator is filled with a substance that is not able to be disolved by petrol or engine heat. It also needs to be able to add a huge amount of surface area to the device. I use stainless steel wool (usually from under the sink).
3. In order to stay within the letter of the law, the EPA require that ALL air from the engine MUST be burnt. Oil/ air seperators, BOV's everything. So, the seperator needs to be reconnected to the intake tract.
4. For cleaning purposes, it is best to have a sperator that is easy to drain and clean. some use a drain hole in the bottom of the canistor which goes back to the sump. I just pull mine out and clean it everytime i do an oil change. I was amazed how much oil it caught!!
Any other thoughts.. :P:huh:
https://www.sau.com.au/forums/topic/14022-oilair-seperator/#findComment-2917485
ohh, i forgot.. some people use scotch brite pads to fill the canistor :P:huh: . These work very well as well. For an even more serious effort, u can fit the scotchbrite into the vent flutes inside the rocker cover. this helps keep the oil in the engine to start with.
Be warned: make sure there is no way that the scotchbrite can be dislodged! this would be fatal to the engine. Also don't jamm it in there damn tight, otherwise it wont be able to breathe. :)
https://www.sau.com.au/forums/topic/14022-oilair-seperator/#findComment-2917501
Not bad...lol..Bringing an old thread back to life r we psi. :P
Yeah, it's good to have a bit of technical input, so you know what you're looking for when buying (or building).
And guess who has got 6 stainless steel catch cans in a production line sitting on the shelf just waiting to be bought.
No. 1 and 2 have already been sold, one to PSI himself and one to me!
Only 4 left.
Edited by 3intheBack
https://www.sau.com.au/forums/topic/14022-oilair-seperator/#findComment-2917812
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
