  • Replies 94
Bunta, Im pretty sure thats what MajorSick meant.
Fri is setup
Sat and Sun is show
so really it does start on the 27th, open to public 28th and 29th
No worries I am just making sure everyone is clear as it read like it was open to everyone on the friday
Paul I belive it is 10am
my skyline will be on show... woo hoo can't wait...
where hasnt ur car been displayed? :)
probably wont go this year. are sau having a display or did that fall through?? who is in it if you are??
they certainly are indeedy. i was in it but had to pull out, should be a quality display :P
I've never displayed my car at salon... EVER
actually i've never even been to autosalon, so i'll be poppig my cherry so to speak.
Most Wanted will have some tuff skylines in there display. :P
SA stand will have some quality cars too
me either LOL
awwww, c'mon man! SAU has a lil display happenin'. 7 cars. Should all go pretty well, I think i've managed to think of everything that needed doing ;) *bites fingernails* hope so...
The best skyline on display will be from Godzilla motorsport.
I saw it the other day and it was nice.... to say the least.
Also had a more expensive motor then the car is worth
is it EASY ST??
cant think anything else...need to get out more
honestly im not a big fan of autosaloon, there is not much to do really.....
but this year should be different...see how it goes
i bet the bottom end alone is worth more than the car itself (that's if it is an OS RB30)
is it EASY ST??
This year will be different because there will be one club at least that is displaying somthing other than rice bombs :)
Most Wanted will have some tuff skylines in there display. :)
hahah i was just yankin ur chain, caus i saw ur car on display at jambo :)
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
