Hey all
I dont post to often on here but now i need ur help...
Im in the market for a new car so i can get around while my project is going thru some repairs and respray etc etc... I have been told of a VL Calais Turbo and im still waiting the news on it and if it becomes available i will be buying it but not to get my hopes up im still looking in other areas and thats when i came across this car..
The Description given was this:
CAR:1987 NISSAN SKYLINE HR31 GTS-T
Pillarless Passage Factory GT Turbo with SIlver Top Rb20DET motor
DESCRIPTION:
ENGINE :- Rb20DET SIlver Top R32 motor. Perfect condition. no Rattles,Smoke or Fumes. Engine only done just over 60,000k.s. Only SYnthetic Oil every 5,000km's. New Timing Belt, New Water Pump, New Aussie Spec Triple Core Radiator and Hoses. Turbo back 3 inch X-FORCE exhaust system(including) X-FORCE DUmp pipe,X-FORCE 3 inch metal cat,X-FORCE 3inch Rear Stainless Cannon with 5 inch TIP ( cost $1,050 Fitted ). POD Filter, Turbosmart Stage 1 Adjustable boost ( Set Safley on 11psi , And never boosted higher ).
DRIVETRAIN :- 4 Speed Auto Gearbox. Independant Rear Suspension, Hicas 4 Wheel Steering, Lowered Springs, Nolathane Bushes, Heavy duty Sway Bars, Electronic Factory Adjustable Shock Settings( Soft,Medium,Hard) mounted in factory console.
EXTERIOR :- Body Straight, No Rust, Paint in excellent condition and always kept polished with MOthers,(front and rear bumpers in general condition paint-wise).
WHEELS :- 17 X 7 ( Legal for this car ) Chrome Mag Wheels, fitted with Nangkang Sport NS II Tyres. Fronts 225/40/17, Rears 235/45/17. Tyres 90% condition, No Scuff marks.
INTERIOR :- Blue Velour trim. Factory Bucket Sports Seats( DRIVERS SEAT with factory fitted AIR CONTROLLED LUMBAR SUPPORT by buttons, Rare Option), Factory 9,000rpm Sports Dash with Gauges including Boost and Oil pressures. SPorts Suspension Adjustable Switch in centre Console ( Soft,Medium,Hard ), Electric Windows( Tinted), Factory Radio with Factroy Graphic Equaliser, Factory Speakers, TAPE STACKER in CONSOLE( VERY RARE FACTROY OPTION and UNHEARD OF BY DIE-HARD ENTHUSIASTS and 5 Motor wreckers in NSW, 2 in QLD, and 1 in SA). Automatic Rain Sensing Wipers, Automatic Headlight Sensing. Rear Window WIper/Washer.
What im wondering is what this car is really worth??? Im not usually one to look at skylines under the r32 but this one grabbed my eye. BUT if its not what i wanted it to be, i want to be able to sell it again and get something that i really want without losing out too much...
Your help would be much appreciated so i hope i posted this in the right spot :D
Cheers Jacob
Edited by FNTA5Y
https://www.sau.com.au/forums/topic/140237-r31-pillarless-4-door/
how much have u got on yours??? i really wanted an R32... but planned to buy once once my VL project is back on the road and looking nice again ready for selling :D
my mates dad is a car wholesaler so if something good comes in i can usually get it VERY cheap hence why i jumped at the Calais Turbo cause ide be getting it cheaper than a nice looking NA VL... i woulda gone thru him for a nice silvia or r32 but they dont come thru very often as trade in's to many people sell them privately cause they can fetch alot more...
Yep, up to 87 is the S1 Pinny looking front end but trust me, many have had these changed (like mine) so best to ask.
Manuals are hard to come by but do exist so look out for a manual would be better and make sure it has an LSD diff (if its important to you) as not all do. I had to change mine from single to LSD but was factory manual. Also bear in mind, wheels are hard to get in the offset with 4 stud.
Also look for one with an RB20DET ECCS, many has NICS engines and even RB20ET's etc.
Other than that they are a great car, I love mine and as they are different they attract a lot of attention. Everyone told me to get a 32, wanted something different and haven't regretted it for a day.
Mine is a S1 that had a RB20ET factory, thankfully by the time I brought it there was a silvertop RB20DET sitting there, phew!
Yer they look ok, prefer the S3 with projectors, mine has the new front end with the old rear, perfect combo, but then I am biased :verymad:
Don't forget the S1 Passages that were equipped with the RB20ET powerhouse :huh:
Even S3 ones were. But obviously not the only choice of motor, given you could have anything from a diesel to a RB20DET ECCS.
a mate just scored one in mint condition minus an engne for $1500, we just spent the weekend transferring his silver top rb20det into it...
S3 Ti front on this one, i got the S3 taillights and Turbo centre garnish of him....
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
