After indicating and sometimes from startup i can hear the indicator clicking noise but twice as fast. theres no lights flashing an the indicators are off an all the rest .. doesnt look like there are any fuses blown
while its clicking at me i can put on the indicator or hazards and it slows back to normal speed and operates as expected. soon as hazards or indicating stops the clicking double time resumes and after bout 5-10 secs it stops (sometimes longer)
anyone had this before?
cheers yall :D
I found the problem in the blinker switch on the steering column. Once I opened the sterring column up and plastic covers off etc...I saw the swithc arcing out on the copper strips on the side of the blinker switch. I out a big blob of vaseline on the surrounding copper strips and I have never had the problem since. This was a 1 year ago now. It may seem its you relay but double check it in the blinker switch on the steering column 1st. Thanks
cheers i'll give that a go tonight! much appreciated :D
  • 3 weeks later...
  jetpilot said:
How did you go with your problem ?
it literally just started again this morning .. although this time it was stuck indicating left and then only after hitting the hazards it stopped but started making the indicator clicking noise at double time again for awhile. ill crack her open tonight ;)
hey mate i had the exact same problem turns out it was the indicator stalk assembly had broken. i just purchased another one from four brother imports (now closed up) for $120 and fixed the problem. Dont know if it makes any difference but this was in an r33 gts-t good luck :(
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
