my r33 has always run perfect, but a few months back i changed a coil pack as it was buggered (the car idled like it had a v8 in it) so after putting in new coil packs and changing the spark plugs things were fine.
no i have a slight hicup at around 4800-5500 but the thing is its not always. 99% of the times it drives without an issue, but late at night when its cool weather it feels like it pops between that range and then recovers real quick.
mods are:
FMIC
10PSI
HIFLOW cat
3"exhuast.
any ideas, my guess is the stock fuel pump
https://www.sau.com.au/forums/topic/140257-misfire-but-with-a-difference/
mods are:
FMIC
10PSI
HIFLOW cat
3"exhuast.
did you gap the plugs?
a few questions:
1. Did you replace your original coil packs with brand new spitfires/oem ones? Or did you get some used coil packs?
2. My car had similar problem, on a cold night my car usuallys boosts a little bit higher then throughout the day and had a small hiccup like you descriced around 4000-5500rpm mark.
Tried regapping my copper heat range 7 plugs from 0.8mm to 0.65mm it was good for a quick fix like others have said on the forum BUT it just hides the truth that the coil packs were on there way out. Car didn't feel as quick as it use to compared with when i ran a higher gap keep in mind.
SOLUTION:
Recently i've ordered a BRAND NEW set of Spitfire coil packs from www.perfectrun.com.au for $550ish delivered.
Didn't change my plugs or gapping (NGK Copper Heat Range 7 plugs 0.8mm standard) the plugs in the car's done around 1000kms.
Just fitted my SPITFIRES coils and what do you know! boost at 1.0bar (low), boost at 1.3bar (high) and NOT one sign of misfire SMOOTH reving all the way to redline LIKE IT SHOULD BE!..
my 2 cents.
thanks mate, i replaced the damaged coil packs with factory ones from another r33 and it fixed all the idel problems i was having, but no i have this small thing happening....if the coil packs are gone again im gonna be pissed
after takin it for a few test runs, my guess is its not coil related, as if i press the accelerator 80% it doesn misfire at all or pop, it only happens when i have the foot to the floor when it misfires, so its the fuel pump which needs an upgrade or the air/fuel ratio
if its only missing at night then you should be right mate all it is, is the cold night air is more condensed therefore partially upping your boost to certain point were your sparks need a smaller gap or you might be hitting boost cut... if shes working perfect during the day then dont worry bout it too much. if its bothering you try getting a boost cut defender and see if that makes a difference. cheers mowie
Edit: just reading over the post again try getting ur A/F Ratio remapped like everyone is sayin if all else fails.
Edited by --{TRYDIS}--
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
