SA rego. Still has 6 months rego on it.
Will get rego details tonight cause personal rego plate will be coming off.
MY98 Hatch
2.5L USDM Sti bottom head
Ported MY98 heads
Parallel fuel rail mod
Walbro 500hp fuel pump
Trust Extractors
K&N pod filter
AVO silicone inlet
Autronic SMC Plug and Play
VF34
Sard 650 injectors
Malpassi fuel reg
JUN BL 3" turbo back exhaust
Kartboy shortshifter, gear knob and bushings
PPG straight cut 1,2 and helical 3,4
5 puck extreme clutch
CSC 330mm rotors and 4 pot calipers
WORK CR kai 17's with Falken Azenis RT215
sway bars front and rear with alloy links
Rear strut tower brace
Whiteline 'H' underbody brace
TEIN HA coilovers
Process West front mount and oil cooler
Defi guages in centre pod (3)
Alarm and key pad immobiliser
Alpine cd deck with ipod adapter, focals all around with splits in the front
Last tuned att 229KW (SA dyno) nice safe tune.
Its been built to be driven and tracked if you like, i have only taken it to the drags once and got a 12.1 on the old tune.
The car has all new wheel bearings.
Serviced every 5000km with MOTUL turbolite
Most of the mods have only just done 10000km and the rest have done about 5000.
I am sure that i have left something out....
Looking for $25 000 o.n.o which is a steal compared to how much has been spent, will also come with a MY99 front bar and indicators.
PM or Email
Cheers,
Rich
Ps. The frount mount is BLACK!!
email: rich (at) anthems.com.au
Edited by Rich
https://www.sau.com.au/forums/topic/140275-my98-wrx-hatch/
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
    • Are you talking about the oil squirters? There is only one place for them to go. Yes, you have to drill the holes. Yes you have to obtain the correct oil squirters (I presume there is some sort of aftermarket option available, because original turbo ones are going to be a diminishing resource).
    • I thought you didn't let mechanics, especially those with no idea, work on your car any more? Wouldn't that mean it won't be an issue in your case?
