Thx for everyone that has participated in EXE DYNO DAY...
it was a great turn out, great wheather too... big surprise on the day was the stock MPS3 pulling 161.7 KW ATW... very impressive result for FWD 2.3 L4 turbo running on stock setup, stock 4psi boost... dynoed at the 5th gear... also tran with his secret upgrade ^_^ and alistair with great output on mildly modded soarer...
hope the result from this dyno day can be a useful reference for whoever interested modding their particular car in the future (keep in mind that wheather, different dyno, humidity might have slightly different result). detail mod of the relating car can be asked directly to the owner of the car in your forum...
RESULT
212.0 KW ATW - Tran (blacks14) - RWD - 200sx S14
168.8 KW ATW - alistair (Aldmo87) - RWD - Toyota soarer
162.4 KW ATW - Silas (Flameboy) - RWD - 350Z (pod filter)
161.7 KW ATW - Cain (KRNAGE) - FWD - MPS3 (stock)
155.9 KW ATW - Dano (DFAULT) - RWD - R32 GTS-T
144.5 KW ATW - Hany Khoury (Hayness) - RWD - 180SX
140.2 KW ATW - Braedyn Corbani (corbz) - RWD - 200SX S15
131.5 KW ATW - Thao (fknidt) - FWD - civic vitR
130.6 KW ATW - James Caws - RWD - 96 Falcon Ute XH
127.5 KW ATW - Joel (Astro) - RWD - RX8
127.2 KW ATW - Stephen (takahashi) - RWD - RX8
126.7 KW ATW - William (YellowRX8) - RWD - RX8
122.9 KW ATW - Jorge (fly_sri) - FWD - Astra SRI T
120.2 KW ATW - Gaspar (typeG) - FWD - Accord Euro *4th Gear*
119.9 KW ATW - Yohan (Curik) - FWD - Accord Euro *4th Gear*
119.4 KW ATW - Andrew H (auzoom) - RWD - RX8
118.4 KW ATW - Kit (Kitbkk) - FWD - Accord Euro *4th Gear*
118.3 KW ATW - Bryan (silver_slug) - FWD - Corolla Sportivo
114.4 KW ATW - Jarrod (jarrodgt4) - AWD - celica GT4
103.0 KW ATW - andrew (Sandy) - FWD - Mazda3 SP23
98.0 KW ATW - Daniel (Dantze) - FWD - 206 GTI
97.8 KW ATW - Chee (sheepo) - FWD - Mazda3 SP23
97.0 KW ATW - Brian (Chompies) - FWD - Mazda3 SP23
94.7 KW ATW - Cam (Cam) - FWD - Mazda3 SP23
88.0 KW ATW - Jason (Unco) - FWD - Mazda3 maxx sport
83.7 KW ATW - Jules (RME1) - FWD - Corolla 1zzFe
75.3 KW ATW - Kate Vanderlugt (91cel) - FWD - 91 Celica 5SFE
67.6 KW ATW - Songaz (fitz) - FWD - Jazz Vti-S
PHOTOS CAN BE FOUND HERE (no 56K): http://www.exe-crew.com/forum/viewtopic.php?t=999
(i couldnt post the pics up here because of this forum post limitation... )
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
