Hey guys,
what do you guys use?
and whats good for not damaging paint on the doors?
also need a blue triangle!hehe
so what do you guys use and in sydney any places?
or you do them yourself and how?
cheers,
Chris
https://www.sau.com.au/forums/topic/140299-racing-numbers-supersprints/
Supersprints usually allocate you a number on the day. Stick it on a window (usually) & it won't damage anything.
Blue triangles - you can either go buy one from somewhere like revolution racegear or do what I did & trundle down to your local sign shop & ask for an offcut of blue sticker stuff. Either that or go for the classy insulation tape. Noice.
thanks mate - yep - they have allocated me a number - but wasnt sure if i get the sticker made up myself or they give it to me on the day (bathurst super sprint)
and your from hornsby arent you? which place did you go to? :(
(i am thinking of the right member yeah??)
I used to make the number up on A4 (in Word), then enlarge it on the photocopier to A3.
3M "Invisible" tape sticks it cleanly to the doors. Only potential problem is if it rains - which, unfortunately, isn't such a major threat ATM.
Now I have a set of proper numbers on a magnetic square. Still use 3M to stick down the leading edges.
As for battery triangle, blue electrical tape works wonders and doesn't stick so hard that you can't pull it off cleanly.
i use a magnetic number. tape the top edge and leading edge, sometimes do all 4 edges if i'm not in a hurry. i've got a magnetic blue triangle too but it dont work on the GTR (alloy bonnet! d'oh) but it's fine on the GTST etc. worth the investment. just if you do use the mag ones be sure to tape them down as nothing looks stupidier than seeing some clown nail it on the straight only to have his number fly (and they really fly) off at 210kph. even less funny if you are driving behind and it lands on your windscreen.
I've also used race tape for numbers, fine as long as you take it off that day and dont leave ti on for a while.
Also blue electrical tape makes a great triangle.
But the easiest way is to buy triangle and numbers from Race and Rally in Greenacre.
  • 2 months later...
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
