Hey guys,
Could i get some info on what a high flowed turbo means please? Is this something you get done to your original turbo or is that how aftermarket ones are made??
Any input would be appreciated.
Cheers
The way i have always taken it as being changes made to an existing turbo, the company makes it then someone else bores it out for more air flow. like when i had my mazda mx6 with an IHI 12 i think when i got it rebuilt i got it hi flowed which ment boring the walls of the copression housing out so it had more air volume.
im happy to be corrected tho if im wrong
Cheers
https://www.sau.com.au/forums/topic/140304-high-flow-turbo/#findComment-2614228
yea nugget is correct. Maybe pm a few of the guys as to the cost and what specs they had done as Race_Snooze and Tridentt both have had them done to there stock turbo's (although i think snooze got rid of his straight away)
The other thing is maybe give GCG a call as they are the ones who do it.
Cheers Leigh
https://www.sau.com.au/forums/topic/140304-high-flow-turbo/#findComment-2614269
Yeah well i want to find out some prices to see if its worth while instead of spending $1500+ for a new turbo. Also, will i need to get new injectors if i high flowed my turbo? Would it increase the power that much?
Edited by R3sp3ct
https://www.sau.com.au/forums/topic/140304-high-flow-turbo/#findComment-2614429
Speak to slide on these forums. he can hiflow your existing turbo for around $800.
for this you get brand new compressor and turbine wheels new CHRA and bored out compressor and turbine housings. it will flow enough for 250rwkw.
I am getting one done right now and will have it in about a week. I will keep all posted on the results.
it is on an RB20 so I will have to settle with 220rwkw bit is should be a screamer.
https://www.sau.com.au/forums/topic/140304-high-flow-turbo/#findComment-2614536
So seeing as i have a fuel pump, power fc, FMIC, pod will i have to upgrade my coils and injectors to run a high flowed turbo?
EDIT: My current injectors are at 80% and apparently that is maxed so i'd have to up grade them wouldn't i?
Edited by R3sp3ct
https://www.sau.com.au/forums/topic/140304-high-flow-turbo/#findComment-2614644
injectors no, coils maybe it depends on what state there in the, but injectors will easily handle 250kw
https://www.sau.com.au/forums/topic/140304-high-flow-turbo/#findComment-2614650
Had mine done [just sold it recently] was really happy with the power, I had 240rwkw at 18psi before I put cams in.
Then I put cams in and [unfortunately] didn't stop there, I pulled my turbo off and sold it [had a very good offer with no hassles] now I'm looking at other turbos etc.
But the high flow was a very good turbo and I estimate would have made around 260rwkw all up.
The turbo is openned up to breath a better. Mine went from 51.2/71 to 56.3/76mm. But my turbo was not a std one to start with, it was a garrett something or rather [not too sure but it went well].
Steve I'll send you my spec sheet so you can see what I have on my 'line to make the power I did. Also if you go to the RB25 turbo results thread in forced induction you will see what other ppl are getting from theirs.
Personally, a high flow for $1000 is a good option. if it goes over this amount then i'd be looking at the garrett GT3071R IW with T3, Slide is selling them for around $1600 and they are a 480hp turbo, so you would be looking at 250-270rwkw with supporting mods.
I'm looking at the HKS2835proS, its a small mods only bolt on. But I'm also looking at the GT3076R IW and the GT3040R IW they require a lot more mods [custom intake and dump and well as oil and water lines] to fit. Overall cost of all options is eventually about the same give or take a $100-200.
https://www.sau.com.au/forums/topic/140304-high-flow-turbo/#findComment-2616041
Well then i'd say it would be a better option buying an after market turbo rather then playing around with my standard one.
I still want to see your mods/figures...
I emailed them to you, along with the photo's etc all sized down etc.
https://www.sau.com.au/forums/topic/140304-high-flow-turbo/#findComment-2616749
but these turbos aren't ball bearing are they?
https://www.sau.com.au/forums/topic/140304-high-flow-turbo/#findComment-2623376
there not, just means they need to be warmed up and cooled down, and oil needs to be kept clean.
ill just get Ed to do mine, it's going to cost me three grand but it will be stell ball bearing and abale to run 20psi or more
https://www.sau.com.au/forums/topic/140304-high-flow-turbo/#findComment-2626315
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
