Hey guys,
Could i get some info on what a high flowed turbo means please? Is this something you get done to your original turbo or is that how aftermarket ones are made??
Any input would be appreciated.
Cheers
The way i have always taken it as being changes made to an existing turbo, the company makes it then someone else bores it out for more air flow. like when i had my mazda mx6 with an IHI 12 i think when i got it rebuilt i got it hi flowed which ment boring the walls of the copression housing out so it had more air volume.
im happy to be corrected tho if im wrong
Cheers
https://www.sau.com.au/forums/topic/140304-high-flow-turbo/#findComment-2614228
yea nugget is correct. Maybe pm a few of the guys as to the cost and what specs they had done as Race_Snooze and Tridentt both have had them done to there stock turbo's (although i think snooze got rid of his straight away)
The other thing is maybe give GCG a call as they are the ones who do it.
Cheers Leigh
https://www.sau.com.au/forums/topic/140304-high-flow-turbo/#findComment-2614269
Yeah well i want to find out some prices to see if its worth while instead of spending $1500+ for a new turbo. Also, will i need to get new injectors if i high flowed my turbo? Would it increase the power that much?
Edited by R3sp3ct
https://www.sau.com.au/forums/topic/140304-high-flow-turbo/#findComment-2614429
Speak to slide on these forums. he can hiflow your existing turbo for around $800.
for this you get brand new compressor and turbine wheels new CHRA and bored out compressor and turbine housings. it will flow enough for 250rwkw.
I am getting one done right now and will have it in about a week. I will keep all posted on the results.
it is on an RB20 so I will have to settle with 220rwkw bit is should be a screamer.
https://www.sau.com.au/forums/topic/140304-high-flow-turbo/#findComment-2614536
So seeing as i have a fuel pump, power fc, FMIC, pod will i have to upgrade my coils and injectors to run a high flowed turbo?
EDIT: My current injectors are at 80% and apparently that is maxed so i'd have to up grade them wouldn't i?
Edited by R3sp3ct
https://www.sau.com.au/forums/topic/140304-high-flow-turbo/#findComment-2614644
injectors no, coils maybe it depends on what state there in the, but injectors will easily handle 250kw
https://www.sau.com.au/forums/topic/140304-high-flow-turbo/#findComment-2614650
Had mine done [just sold it recently] was really happy with the power, I had 240rwkw at 18psi before I put cams in.
Then I put cams in and [unfortunately] didn't stop there, I pulled my turbo off and sold it [had a very good offer with no hassles] now I'm looking at other turbos etc.
But the high flow was a very good turbo and I estimate would have made around 260rwkw all up.
The turbo is openned up to breath a better. Mine went from 51.2/71 to 56.3/76mm. But my turbo was not a std one to start with, it was a garrett something or rather [not too sure but it went well].
Steve I'll send you my spec sheet so you can see what I have on my 'line to make the power I did. Also if you go to the RB25 turbo results thread in forced induction you will see what other ppl are getting from theirs.
Personally, a high flow for $1000 is a good option. if it goes over this amount then i'd be looking at the garrett GT3071R IW with T3, Slide is selling them for around $1600 and they are a 480hp turbo, so you would be looking at 250-270rwkw with supporting mods.
I'm looking at the HKS2835proS, its a small mods only bolt on. But I'm also looking at the GT3076R IW and the GT3040R IW they require a lot more mods [custom intake and dump and well as oil and water lines] to fit. Overall cost of all options is eventually about the same give or take a $100-200.
https://www.sau.com.au/forums/topic/140304-high-flow-turbo/#findComment-2616041
Well then i'd say it would be a better option buying an after market turbo rather then playing around with my standard one.
I still want to see your mods/figures...
I emailed them to you, along with the photo's etc all sized down etc.
https://www.sau.com.au/forums/topic/140304-high-flow-turbo/#findComment-2616749
but these turbos aren't ball bearing are they?
https://www.sau.com.au/forums/topic/140304-high-flow-turbo/#findComment-2623376
there not, just means they need to be warmed up and cooled down, and oil needs to be kept clean.
ill just get Ed to do mine, it's going to cost me three grand but it will be stell ball bearing and abale to run 20psi or more
https://www.sau.com.au/forums/topic/140304-high-flow-turbo/#findComment-2626315
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
