JAYCAR INDEPENDENT ELECTRONIC BOOST CONTROLLER
FULLY BUILT AND TESTED, hand controller is needed
$190 INC EXPRESS POSTAGE
JAYCAR DIGITAL FUEL ADJUSTER
HAND CONTROLLER plus cable
$140INC EXPRESS POSTAGE
IEBC + DFA + HAND CONTROLLER=$450 INC POSTAGE
EITHER IEBC OR DFA + HAND CONTROLLER = $310 INC POSTAGE
It will take 1-3 business days from payment received till you get items.
These products are new and come with wiring and instructions, and very easy to install, you will need to keep your standard boost solenoid.
I build these and test them on my r33, as a service to skyliners, for those out there who can't solder and don't want to risk stuffing them up.
Elsewhere on the net they are selling built and tested ones for alot more than these prices(ie IEBC is around $275 delivered), and your local electronics shop will most likely charge hundreds of dollars to build these for you.
You can buy the kits at your local jaycar dealer for around $80 for each item, if you're good with electronics.
Please PM, email or phone me on 0418 342 710 with orders.
Thanks
Chad
Edited by chadr33
Hey man did you solder these up yourself?
And I assume you had them running? What car were they in? How well did they work? Are they easy to install?
I was looking at getting a SAFCII but all I really want is to clean up the AFR's, so this might be suitable.
-Insu
Hey mate don't worry about answering the above posts, I've just seen how much the kits sell for!!
I'd rather put one together myself.
-Insu
http://www.jaycar.com/productView.asp?ID=K...=&SUBCATID=
Edited by insu
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
