  • Replies 281
yeh im stinging to see what she makes?
does anyone no what boost the 2860r make on the actuator setting they come with?as im not running any sort of controller/
I've heard the wastegate spring is adjustable, and that the factory setting is 1 bar.
That's second hand info, so treat it as such.
Dan
It depends a bit on the exhaust system but if you have a free flowing system with high flow(or no cat)cat you should see ~0.9 to 1 bar boost off the actuators, and a reduced boost level if the exhaust is restrictive at all.
pete
i have justjap dumps whick look to be nice and free flowing,2.5inch in to 3inch stainless dumps,stock gtr cat and 31/4inch titanium cat back. i want to run about 22psi so how should i adjjust them? or should i run a bleed valve
the std cat is going to have a dramatic effect on the system and why do you think you need 22 psi the extra boost doesn't always gain big results the -5 i have found on the rb26 seem to hit a sweet spot around 18 psi and the after 20psi the gains for boost increase fade, so for the extra stress your putting on the engine and turbos it's offen not worth it. 18psi quiet offen can see a healthly well sorted rb26 pass 510rwhp+ but if your looking for figures inexcess of 530-540 your should most likely be looking for a different combo and you'll have to sacifice responce to do so.
As for controlling 22psi you WILL have to buy a electronic controller to get the consistent control required or you will suffer the swings in boost pressure from different temperature conditions which at that level could be dangerous at 18psi a swing of 1 or 2psi isn't to scary but 22 plus 2 or 3psi and your getting very close the design limit of the centre cariridge of 2 bar.
pete
Edited by pnblight
pete
thats the info i was after,so 18psi should see the 320awkw im after or maybe bit less wouldnt matter?
profec b sounds to be ok so i might look into them.. thanks again all
  • 1 month later...
I'll 2nd Seans call on a MetalCat. I bought my GTR with a straight pipe in place of the cat & when I swapped it out for a 4" MetalCat flanged back to 3" to match the exh there was basically no noticeable difference in performance whatsoever.
BTW didn't you lose your licence awhile back?? Might explain why you're in no real rush to throw everything at the car ;)
BTW didn't you lose your licence awhile back?? Might explain why you're in no real rush to throw everything at the car :P
He'll be on the road again, before you know it.
Not when all the parts are ready to put on. :happy: get moving!
yyeh yeh im just getting motivated...4months 1 week till im legally aloud to drive again so ill prob get more motivated then...
still its a pain not even being able to start it and hear the noise of my rb26....grrrrr
Man, i there with you. Mines been off the road for.. *gulp* 12 months. Have a mass of power steering lines to re-route, 12v feeds to run through the cabin, engine oil cooler to finish lining up... all waiting till i can get my tahbin and m.fold - i LONG for the sound of the RB again
It can often be hard to get under the gurl in the ever colder nations capital, to be covered in PS fluid.
At the moment im on a raising rate dose of HiOctane / JDM vids, plus 80's Rally docos' and rides in mates fast rides
Almost there, have faith man
M
Edited by GeeTR
    • Good to hear. Hopefully you're happy enough not to notice when driving and just enjoy yourself.
    • I mean, most of us just love cars. Doesnt necessarily have to be a skyline.
    • Did you pick up a manual cluster to remove the position indicator?  (Pretty sure the 34 has the gear position in the cluster, but it's been a while)
    • Here is a recipe. Sonic blocks till you get one that has a good enough bore. Get a torque plate and block brace, use your choice of fasteners (arp ect) bolt the thing together empty, half fill it and let it cure. Release it when it has, go to a REPUTABLE RB Builder and get the thing line bored/honed and cylinder honed to size, then wash. Once its all clean and dandy, wash and blow it out again. Then again.  Assemble said engine to your desired clearances with oil control mods, gasket to suit desired CR/Squish ect. Attach your extended sump with proper trap door oil baffles and head drain plumbed to sump with a SUMP BREATHER SYSTEM. Build your front diff with a decent LSD, rebuild your transfer case with a few extra plates, more than likely replace your tailshaft centre bearing and tighten up the rear diff. Tune to minimise excessive midrange cylinder pressure (timing unless you like to split bores and rebuild engines) Enjoy your engine, but hate the fact you are now destroying engine mounts, gearboxes, gearbox mounts, diff output flanges and driveshafts, diff mounts, tailshafts and front CV's.   Disclaimer.... Ive never done any of the aforementioned stuff.......
    • 440s will support well over 400HP on petrol, which is a decent place to be for an RB20. 230+rwkW. Will be a safer bet for idle/low load. 550s would be nice for the extra headroom. I've made the same decision with mine (Neo25). 1000s are probably too big for the Nistuned ECU, so I have some smaller ones.
