I think Nismoid you are mistaken.
I have 330rwkws on a rear wheel dyno and 260awkws on a 4 wheel drive dyno.
Both are different.
gtr32 has already the 320kws at the wheels he is asking for help with mods
to get him to 400rwkws.
Tuners also give you results in shoot out mode because it is a higher value.
In shoot out mode I have 370 rwkws with the 2530's,set at 1.3 bar
I will though clarify with my tuner tommorrow ,but of what I have read this is a correct statement.
Thanks for you help Nismoid in bringing this to my attention.
Cheers. :)
  • Replies 281
Both are different.
Cheers. :)
Im definately not mistaken. Please stop bringing mis-information into the thread.
I know what im talking about.
He does NOT have 320rwkw, thats what he wants. I dont know if you've read the first post correctly either.
He is looking for a turbo upgrade, ie, he doesnt have upgraded turbos as yet.
And he does not want 400rwkw. :P:rolleyes:
There is no way going from AWD ro RWD you loose 70rwkw
Thats madness and very very very incorrect
http://www.skylinesaustralia.com/forums/in...3&hl=*awkw*
Scroll down the Dirtgarage's post. Sums up what we are talking about here.
Simple enough to find using the search function, so not sure where you have "read" that awkw/rwkw is a 70kw difference, as its never been posted as such on this forum that i know of as its just rubbish :)
this correct. looking for 320awkw have well i dont no. my car is going on a dyno tommorrow so it will interesting to see how much power my car has...
exhaust,.9 bar of boost..so about 180kw yes.
by the way i have a faIR idea of the cars condition as it has only 89xxxx on (i no this could be incorrect)but the rest of the car seems to tell me its about right.
before i bought the car i made the bloke get a comp test at rigolis and all come back 150 throughout the 6....makes no funny noises and motor sounds tight?
say i had the cash would it be worth putting a n1 oil pump and collar?
kane
also the dyno im putting my car on is rearwheel dyno! i was just going to pull the 4wd fuse? will this be 100% rear wheel drive or cou;ld maybe slip some how fronts spin a little? just i dont want this top happen
to put a collar on = motor out.
So its not worth it unless your rebuilding it.
RWD - i think the fuse is ok on the R32 GTR.
You could always just drop the drive shaft, thats what R33/R34 owners have to do, takes a few mins, nothing major
044 needs cradle modification. Nismo pumps bolt straight in but cost ~$200 more :devil:
....Also i think you means 9psi?! or is it 0.9bar?!
....Oh, I see the 'point' now :wave:, I say you could expect closer to 200-210rwkw if you your not talking awkw
Sorry, theyre $230 and theyre an intank swap for your old one
the cradle needs slight modification but nothing the backyard mechanic cant do
theres a tutorial for the 32gtr in the tutorial section...have a look!
thanks slippery, ill have a look..
also i got a quote for nismo afm. $480 each... i think ill just stick with the stockies and see if they bottom out as im not sure when they would??? ideas?????
Dirtgarage tested RW & AW it, 1kw difference which is nothing but dyno variance at its best.
This only seems to work on a Dynolog (Mainline) Dyno...i don't know why but Dyno Dynamics reads higher in RW...dunno why...it just does.
We have been able to "spike" the figure in RW on a DD dyno by only about 30kw which seems about right on a 450AWKW car.
BUT...this is not a dyno thread so sorry to get off topic.
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
    • As above, replace as many as you can afford. If anything, due to old age.
