Intercooler water spray trigger point
22 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Mad082
That's why you also need a low cap on the turn on point. spray wont activate until a certain temp. on a 40 degree day, the lowest you will be able to get the intake temps is 40 degrees.
using just a hobbs switch would very quickly run out the water supply
I ask this then - if the spray is triggered based on a temp, then what advantage would reading the the inlet temperature be over having the temperature read at the outlet side of the intercooler. After a good workout, an intercooler core inlet side will be hot and the outlet side will (hopefully) be cool. Having the thermistor mounted in the fins right next to the outlet end tank should read a very similar temperature to the engine inlet temps. I don't think there would be much of an advantage using an inlet temp instead of intercooler core temp as the comparison against ambient temps.
by inlet temp i assume you mean IC inlet temp, and the advantages of that i what is wrote in response to pauls post on the first page. i would mount the sensor in the actual stream of airflow, rather then taking temps of the core itself. if the cores temp is too high, it will show on the temp of the intake charge, so measuring that i believe is more effective. the primary concern is air charge temps, and measuring the cores temp doesnt always give a good indication of that.
An intermitant spray of say 2 in 20, and a off switch and to full for the hot runs, and really its the hot season that a cooler comes into its own, if you want to measure heat soak you will be wanting to monitor the actual metal temps, so a sensor away from the airflow on the cap end of outlet would give a realistic reading, when you have it up and running pm me with details please
Terry
Actually - when I said inlet temperature, I mean inlet into the engine temperature - AFTER the intercooler.
I agree that the the primary concern is the air charge temps into the engine, and measuring the actual airflow rather than the outlet side of the intercooler code may provide a more accurate temperature reading (though how much more effective that would be can't really be substantiated without actual tests and numbers). Unfortunately it comes down to cost. For a lot of people, cost will be a deciding factor whether to purchase an intercooler spray or not rather than getting that extra x% effectiveness.
Another mode for the water spray activation would be to use the ECU earth wire from the stock boost solenoid... you will have spray from 5000RPM till Redline... Just a thought
Regards,
Sarkis
  • 3 months later...
Well the intercooler spray controller I was designing and building has been finished, tested and ready to buy if any wants one. See http://people.aapt.net.au/~mearcat/Kits for some very postitive test results thanks to Ian (ID : CEF11E). It basically replicates the well-known Autospeed intercooler spray controller functionality but for HALF the price and half the box size too.
    • Hmmm, what do you mean by getting weaker? And where did you get that test done? I've been wondering about my battery because the cold starts crank super slowly. The voltage is fine. Not sure if cranking amps can be checked at home. Battery is 4+ years old.
    • No. The simplest wastegate hookup, with no solenoid or other form of "boost control" (ie, control over your boost control, if you know what I mean) is a single hose, direct from the turbo outlet/hot pipe, straight and only to the wastegate actuator. It is that pressure signal that drives the wastegate to open, providing the boost control (and by "boost control" here, I mean, limiting how high it can go, which is essentially the spring pressure of the actuator). You only end up with tee pieces and alternate flow paths once you start adding things to the boost control system to allow you to determine how much of that boost signal makes it to the actuator. There are so many ways to do that that there is no single way to run the hoses and tees and the like. If you have a stock boost solenoid, then all it does is either allow all the boost signal to go to the actuator, or open up to allow some of it to bleed off. There needs to be a restriction in that bleeder to allow only a small amount to bleed off. And in a stock system, that would then be plumbed back to the turbo inlet (for "emissions control" reasons). That is actually what that nipple on your BOV return pipe could/would be for. If you have an aftermarket boost controller and solenoid, then the above is mostly true, but there is no need for a restrictor in the bleed, because the solenoid is pulse width modulated to create a variable bleed off. The air that escapes from the bleed can either be vented, or also returned to the turbo inlet. For emissions reasons it should be returned to inlet, but the amount of air being vented is so small that it really doesn't matter (either from an emissions perspective, or from an air-fuel ratio affecting perspective).
    • And other times you just need to go buy bigger injectors?
    • Yup. I actually just blew my turbo. LOL.  should have checked this thread before today. i also have no boost solenoid. so it should be...one line from wastegate to turbo inlet, and a T somewhere in that line that connects to the wastegate return pipe?
    • It's recommended, however I can assure you a good amount of people don't bother. FWIW, the OEM battery lasted 4.5 years and I changed it prematurely too, I reckon could have stretched it to 5 years.
