  • Replies 78
Corners are where the funs at ;)
There's a really cool hairpin at the end of the strip.
Every time I get there, I'm always tempted to just rip the car into that perfectly paved, wide open, 180 degree bend and just try and drift through it. ;)
https://www.sau.com.au/forums/topic/140333-wsid/#findComment-2615339
it should be good having it both days.
hopefully have some time next weds to go down for the first time, anyone going next weds? if anyone sees me in a stock looking white r32 come say hi
dead32 all the prices and stuff are on the WSID website.
https://www.sau.com.au/forums/topic/140333-wsid/#findComment-2615555
No ET limits, just 95db (track) noise limit.
"EVENT DETAILS:
FULL THROTTLE FRIDAYS
RACE FOR REAL – Starts Friday, November 3!
The Only Limit is Your Imagination.
Gates Open 5pm
Spectator Gates Open from 5:30pm
Racing 7pm-midnight
Video Screen Music, Cranking Atmosphere!
Pricing:
Competitors - $45
Spectators - $20
Kids Under 12 - FREE!
Location Information:
Western Sydney International Dragway
Ferrers Road, Eastern Creek
Web: www.wsid.com.au
Phone: (02) 9672 1320
Email: [email protected]"
All info here:
http://www.wsid.com.au/default.asp?Page=Article&ID=305
https://www.sau.com.au/forums/topic/140333-wsid/#findComment-2618744
Every time I get there, I'm always tempted to just rip the car into that perfectly paved, wide open, 180 degree bend and just try and drift through it. :rolleyes:
I get the same urge..
on my last run out there i left the window down.As i was driving back one of the fire officials called me in and lectured me on the non-saftey and how my arms are prone to flying out in the event of an accident.I totally agreed with him,and diddnt argue the point.I diddnt even point out that if their officials were doing the job that they were supposed to be doing that i wouldnt have had the problem in the first place.lol.sad but true :P
https://www.sau.com.au/forums/topic/140333-wsid/#findComment-2619025
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
