If you want load and angry.....straight through custom 3" pipe and hot dog with no silencer.
yer, i got this, 3" with just a hotdog at the end off hiflo cat and 3" batmbl dump
surprisingly not that loud (probably over 92 decibels though)
sounds great though
not even that droney
I have an SR20, but have a custom 3" exhaust with a hot-dog and a small cannon. Sounds pretty angry. A workshop thought that I had cams because of the way it idles. I told them that it was almost impossible because I bought the car stock and had not done any cam work to it.
I have:
Batmbl front split dump
Metal Cat highflow cat
Apexi N1 catback
The apexi part has a muffler in it about half way down, the difference I've noticed between this on my car and other R33's with full length exhausts is mine tends to be quiter and idle, and mine also seems to have a lower or deeper burble to it.
That all changes once you hit boost though, you get that lovely metalic almost sound of the turbo spooling then the exhuast just starts to get angrier then by the time you hit 'high' boost it sounds like it just wants to take off.
I'm very happy with my exhaust combo as you can probably tell.
My Fujitsubo is loud. And I mean LOUD.
about 97db.
3.5 inch centre, 3" rear. I have taken the rear section off and swapped for a Magnaflow 3" for street driving because the Fujistubo is too loud.
I have:
Apexi N1 catback
How much is the split dump you have?Does it go all the way into the cat like a front pipe?How much for SAU members?
CHEERS
CHEERS
Pipe goes from turbo to cat. Seperates the wastegate exhaust gases from the normal exhaust gases for a fair bit, =better for power than the all combined units you see getting around.
Last times prices were: $395+$15 delivery for the mild steel
or
$410+$15 for the stainless.
I got the stainless.
I suggest you contact Batmbl via pm.
Check it out: http://www.skylinesaustralia.com/forums/in...showtopic=74022
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 馃檹 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 馃槈. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 馃槏 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
    • All my Polish car culture insight comes from watching Nightride. So I half expect this to get 1UZ swapped eventually?! Are you going to drive it in winter? I'm always curious how ATTESA would hold up in the snow. There isn't that much opportunity to try it in Australia.
    • My steering lock unit on my Infiniti G37 has failed. The car is a local 2012 Infiniti G37 (Q60 ) I need to replace the unit My local mechanic said i need to buy a complete steering wheel assembly. Does anybody no any mechanics in Gold Coast or Brisbane who can fix this issue or where i can buy just the Steering lock control unit. Thanks
