yeh i've found this out too (the hard way)
i was changing my filters over and i forgot to plug the afm back on started the car n it was ideling like shit i thot oh my god wat did i do??? i didnt think it wud be the afm not for 1sec coz i thot the car wudnt start but yeh i looked around and found that the afm wasnt plugged in i got so relieved wen it started idelling good.. phheww
Edited by assyrian4evaa
https://www.sau.com.au/forums/topic/140350-afm/#findComment-2615129
funny enough, I had the AFM unplugged before due to my paranoia after it was stolen once, I thought unplugging it would cause the car to idle like shit and deter opportunistic thieves. Well, one day, after starti9ng the car, I realised I hadn't actually plugged it in and it was idling quite well unlike the previous time where it wouldn't even idle....so that was a bit of mystry
https://www.sau.com.au/forums/topic/140350-afm/#findComment-2615563
HOW the FU*K would the car know how much fuel/air to mix if i cant calculate the air flow without the AFM
The car would look at its other inputs... e.g. Coolant Temp, RPM and put in a pre-calculated amount of fuel. The Fuel map in the ECU would tell it the values - and since your off boost, it should be able to get away with it a bit.
Cars do have to have a bit of tolerence if they lose a sensor, they may not run right - but they should be able to let you slowly drive home.
Cheers
Sumo
https://www.sau.com.au/forums/topic/140350-afm/#findComment-2615965
