My 32gtr seems to have lost the love to drive nicely or it just absolutely hates brisbane roads.
In the past couple of months I have time after time done alignments because of bad steering. I have taken it to a reputable suspension factory and they have told me various things about my issues.
My issues are:
1: When i drive my steering "jumps" around a lot and seems to tram-track the road always.
2: My left hand tyre is bald now and the right one is coming down quickly.
The reputable suspension company told me that my lower ball joints are worn and needs replacement. This seems like a fair comment as he showed me where this part was and how it affected my steering.
Does anyone else have any ideas that can satisfy my hungry mind to fix my problems? Is there any other place on the steering that can cause issues like mine?
Thanks you and enjoy
https://www.sau.com.au/forums/topic/140385-wheels-and-steering-issues/
excess bumpsteer can also be caused by excessive lowering
what is the centre of rim to guard height?
No idea mate, I would have to check it out in the morning. I know its lowered because its not as high as stock gtr. There is a slight camber to the wheels. As far as I know, there isnt any camber adjustment parts, pretty sure they are stock.
i have this same problem in my 33 gtst. i got a hicas lockout bar thinking it would fix my problem . . eeeerrrrr . . . WRONG!!!
had a suspect ball joint fixed . . . eeeeerrrrr . . . WRONG!!!
the suspension place im going to atm are "reperable" but its spent 3 days there n they still have no idea?
Mate i have a friend who reckons its the wheel bearings at the front, worn out. check that out mate, thats what im going to check on mine.
  • 6 months later...
tram-tracking won't be helped by worn out tyres, particularly tyres that are worn unevenly. Wider tyres are more prone to tram-lining, and uneven or low tyre pressures can also contribute to the problem.
anything in the steering system that has any play in it will allow a wheel to move slightly and steer the car causing these kinds of probelms. Ball joints, tie rod ends, the steering rack itself, control arm or castor rod bushes...
if the ball joints are worn, start by replacing them. Even if it doesn't fix the tramlining, it still needs to be done. If all the steering components are OK and the wheel alighment is fine, get some new tyres and see if that improves things.
are 235 wide tyres excessively wide and likely to contibute to tram lining?
is it possible that wheel beaings will cause the problem?
the problem has been slowly developing over the past 3 years.
also, there is a shudder when i brake which i think is related to this movement in the front end (i have had discs machined, wheels balanced)
appreciate any thoughts
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
    • Do you have a picture? I assume it is a breather for gearbox oil as it expands, it should have a vacuum line run nice and high in the engine bay (R32 GTR has it on a top bellhousing bolt)
    • Hi all, I am putting an r33 gtst gearbox into a VL and have noticed what looks like a vacuum barb on the box (on top in the middle). Suspecting that it's a vacuum line but I'd like to double check, if someone could confirm the function of that would be great. Cheers in advance.
