Hi guys..
Ok.. done a search already on this..
After installing a catback exhaust, it is making these POP noises when coasting in gear. Kinda like gun shots.
My car (r32 GTST) is standard minus a pod filter, walbro fuel pump and catback exhaust. It is running 0.8 bar boost (13.5 almost 14psi)
So I've concluded that I'm running rich and that the fuel is not getting burnt and shot into my exhaust which is hot.. where it ignites and makes the bang? I am correct so far right?
Anyhow.. my questions are: how come my car is running rich with such very few modifications? what is the explanation behind this?
How can i get it to run normal? It's come down to a retune or an SAFC.
A Retune on a stock ecu running such little mods is stupid IMO.. but how much will it cost roughly?
And how much rougly would it cost to install/tune a SAFC?
Thanks in advance, Ben.
https://www.sau.com.au/forums/topic/140396-exhaust-popp/
The standard exhaust is designed to restrict engine power, to keep with ADRs, what happens when you open it up is, the engine produces more power at the rev range> more air so the ecu adds more petrol to be safe.
https://www.sau.com.au/forums/topic/140396-exhaust-popp/#findComment-2617744
Your stock ECU at that boost level is useless
Definiately need a 3 inch front and dump pipe giving you 15-20rwkw
Your at the limit the stock turbo can handle I recently got an SAFC 2 and it's a must with 14psi
I got my SAFC from Nengun for like 350 installed it myself and cost 200 for tune
Good Luck
Edited by Tuffr32
https://www.sau.com.au/forums/topic/140396-exhaust-popp/#findComment-2617899
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
    • Jousting sticks! Tell 'im he's dreamin!
    • GTR owners are wankers - 2025
