1994 model
manual
burgandy in colour
BIG front mount
Dual stage B/C
NISMO lowered springs.
NISMO quickshift
NISMO exhaust with JASMA rear muffler and 3" dump pipe
NISMO adjustable castor rods
GTR cams
GTR fuel pump
GTR brakes with semi metallic pads
new platinem spark plugs
M's air pod
IMPUL race pedals and MOMO corse foot rest
BLITZ FET/FAT turbo timer
brake lock kit
TAILSHAFT LOOP
17" 6 spoke wheels
sport steering wheel
leather gear boot and hanbrake cover
interior absolutely immac no holes or tears anywhere
JVC CD player
semi mettalic brake pads and disks machined
400R body kit fitted
aftermarket horn
3 point immobiliser alarm with keyless entry, remote start
6 months NSW rego
much much more
price of only $21000.00 FIRM
call me on 0408 605 725 for more info or emial [email protected]
https://www.sau.com.au/forums/topic/14040-r33-urgent-sale/
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
    • Try using Penrite 80W140, has Limslip predosed into it
