i have NEO 25det controlled by ECR33 ecu. NVCS is wired correctly and working in some way -- i`ll try to disconnect it and try to see the difference :(.
sweet that would be awesome
Guys just a little confused I have CP pistons for 25/30 (compression 9.0) now can I or can I not use the NEO head? THANKS
Im assuming that these are the dome top pistons, if so you will end up with about 10:1, only ccing it will tell you though.
there flat tops
Then they should be good, still need to cc the package and figure out which head gasket you are going to use to determine your final comp. As for running the neo vct on an r33 computer, i dont see how it could work properly, as ive been told the neo has about 40deg inlet adjustment, wheras the 33 only has about 10, which is swiched, not variable. I guess you could fit a 33 camwheel and then it should work the same
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 馃槀  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
