hi im wondering if anyone could help me?
i have a problem with my rb26 regarding with the oil pressure, everytime i hit high revs or hit boost the oil pressure goes down to 0 and the warning light will turn on.
if i drive normally without going over 4-5000rpm its ok, the pressure doesnt drop and the warning light does not turn on.
i would appreciate any help thanks.
cheers,
https://www.sau.com.au/forums/topic/140422-oil-pressure-low-on-my-rb26/
The warning light is completely independent of the oil pressure sender that is commonly faulty. If the pressure on the gauge drops but the light does not come on, youre usually ok. If the light comes on you (99% of the time) have a genuine mechanical problem.
I would be taking it to a mechanics and get an external oil pressure gauge hooked up to see what its actually doing. If it is losing pressure at high rpm then youre probably going to end up with an engine out job.
Edited by Amaru
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
