Hey,
Is there a fuse or anything that controls the horn?
A mate installed a steering wheel for me about 2 years ago now.
All of a sudden today when i got into work it started beeping without even touching it.
Now when i turn the wheel or something the horn goes off and its kinda annoying and embarrasing.
https://www.sau.com.au/forums/topic/140463-bloody-horn/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
