I know that this post could cop a fair bit of flamming etc etc, but I was just curious the other day, what kind of costs/things would be involved in Turbo charging a commodore say a VS,VT or VX?
Obviously Turbo charger, and a tune etc etc
but what kind of costs are we looking at?
https://www.sau.com.au/forums/topic/140569-turbo-charging-a-commodore/
  • Replies 74
Let me be the first to say :):)
Since the V engines you either looking at twins or one complex bitch of a manifold. Then you have issues with the stock compression and engine management. There was some kind of commy wagon with a turbo at the last dyno day I was at that pulled 195rwkW with over 200k's on the engine.
I'd say your better off selling and buying a V8 or maybe getting an XR6T if your into the aussie turbo. A v8 will definately sound better. Your not going to get a good answer on here, definately try a holden/commodore forum.
The compression in the engine is to high and you will need to deal with this first.
Then you need some savvy and choose a turbo that compliments the motor.
Get some custom work on inlet,manifold,exhaust and intercooler mountings.
You will need to re-tune your car and set up a boost controller.
After you have spend 1000+hours and $7000 and the thing is not working right
because you nhave other problems...ie fuel pump or injectors or mis-firing etc etc etc.
It would have been better off buying a gtr32 for $20000.
Hope I have been of some help. :):)
You are better off super-charging this gives you good gains and can bolt up to your set-up .
my mate single turboed his vr commodore, had the turbo at the front of the motor which melted the clutch fan then about a month later blew the motor, was only running 11psi but was pulling a nice 225rwkw's!
The thing pulled like crazy while it lasted.
Unless your going to rebuild the motor don't bother!
i think with a small budget you can bolt on a smallish turbocharger and get some good gains but the issue with the v manifold is a big problem
so you would have to go small twins. as long as you dont want captain insano power it should be reasonable ish, but it will all be custom, which is where the costs add up, i dont think there would be many off the shelf kits
V6 commodores - they have the worst engine I have ever worked on. Absolute rubbish - nothing like an rb.
Totally agree, I use to own a shit box commodore, biggest load of shit....
I don't think I've ever seen such a bad collection of bad ideas put together in the v6's. From balance shafts, super long timing chains to pissweak conrods and water pump bolts that go through to the water jacket - they are a pitiful excuse for an engine. Pushrods??? They were supposed to go with the red motors and dinosaurs.
Edited by gtst25
http://www.ls1turbo.com.au/ttspecs.htm
http://www.otomoto.com.au/kkrturbo.htm
i would hardly say it works out crap...
sometimes people on here are quick to diss anything which isnt a skyline.. which is pretty funny when a lot of people are driving stockish 33's
Let me be the first to say :P:rolleyes:
I've seen that car, he came to my work and bought some parts. I saw the sticker on his windshield saying "Ovaboost" and I was thinking wtf its a commonwhore.. Then he popped the bonnet and theres a turbo bigger than my head strapped to the side of it :) . He reckons when he got it done the standard auto lasted as far as him driving away from the workshop and planting it for the first time ahaha.
Car looked like a bit of a POS though, but a V6 wagon that runs 12s is a pretty impressive achievement
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
