Hey guys so I had my future skyline checked over today by TopRacing "Must say Awsome company, easy to deal with and willing to give you their time"!
Ok so heres the deal: The found nothing majorly wrong with car except few minor wiring problems! Ignition is fueling when switched to accessories 'instead of 2 secs stop it is continue to pump fuel' kinda dangerous but easy fix! 4th gear grinds a little bit with quick shifts! apparently an easy enough fix
The Problem 'Compression ratios' 150 145 140 140 135 125? The guys say its not that unusual and the car could last quiet a bit longer without any problems? Any opinions would be greatly appreciated as i am purchasing vehicle on satdy!
They quoted me about $4000 to completely rebuild engine (stock internals 'no forgies) does this sound right?
Is there any other ways around this?
So anyway I was able to negotiate with seller and he has knocked a further $2000 of the car! which I feel is fairlly reasonable? I love the car and it seems this is the only future prob i may be faced with!
Would greatly appreciate opinions?
Cheers,
Dan
https://www.sau.com.au/forums/topic/140578-compression-ratios/
Cheers,
Dan
hi mate, there is quite a bit of difference between those pots sounds a bit tired. normally 5-10 is ok, but anything more isnt crash hot.
has there been much work to car? wat boost it running? or what was it running.. wat kms has it got on the clock?.
just did mine the other day, mines done 170k+ now,
and mine was 175-175-175-175-175-175
hope that gives ya some insight. good luck :(
hope that gives ya some insight. good luck :devil:
Cheers for reply!
Car has 140000km on it, Boost controller running a bar when switched on!
New FMIC, new fuel pump, radiator, clutch the guy has $13000 in receipts with car!
Those compression ratios are awsome is it a rebuild???
Yeh im reconsidering now instead of him knocking $2000 off i might put it to him that he needs to knock $3000 off?
$16-17000 car with rebuild I believe would be fairlly good value, and least you have reassurance that internals are spot on!
I find old skylines will have corroding head gaskets problem..I got quoted around the $4000 to set things right as well...most ppl in this forum said it can be done within $1000.
Yeh Im thinking Gasket to! But for $4000 may aswell do a rebuild; chuck in the forgies + bore what extra $1500-$2000 still thats a lot more then I have atda moment!
$1000 what would that get you? Do you mean as in cut the 20 odd hrs of labour out ($2000), shit id be exstatic if I could get out of it for $2000!
    • Wrt the engine, you're very much limited by 'production quality' as to how much extra power you can extract from them (I'm talking i6 red-motor) -- a lot here depends on how 'authentic' or 'period correct' you want the modifications to be... ...I'm too old... <grin>...the first true performance engine Holden made, was in the HD/HR models ~ this was the 'X2' performance pack...it came with twin downdraft strombergs on an otherwise unimproved intake manifold, with a two piece exhaust manifold (reckoned to be as good as extractors)... ....these engines were built upon the '179HP' cylinder block, which included extra webbing in the casting to make it stronger and less susceptible to block distortion... The next performance i6 came out with the HK Monaro (also found it's way into the LJ GTR Torana ... the car I wish I hadn't sold)...it had pretty much the same manifold setup, but was built against the '186S' block...this block retained all the extra webbing of the 179HP block, but added a forged steel crankshaft (instead of the stock cast crankshaft), because it was possible to snap the crank... ...apart from the inherent weaknesses in the stock (cast crank) blocks, the next limiting factor is the cylinder head porting & combustion chamber design, and the actual valve sizes. Back in the day, you could buy a 'yella terra' cylinder head (from stage 1 to stage 5 gradients), and this was the way to get serious power out of them -- with the extra breathing of these heads, you could fit a triple SU or DCOE Weber setup... ...obviously, these mods were a waste of time on a stock cylinder head/camshaft grind. My housemate rebuilt the i6 in his VH dunnydore about 6 months back -- this is a 186S block with the 12port 2850 blue motor head and intake/exhaust manifolds, with a dual throat Weber off an XF Falcon mounted on an adapter plate ; it's not a bad makeup...got more torque & fuel economy just light-footing it about on the first throat, but stand on it and it makes more giddy-up than the standard 2850 blue motor that it replaced. Personal note: I'd just fit an RB30 and be done it it 馃槂
    • Thanks for sharing. That's a great video! My buddy is doing the same thing on his build (S chassis struts and towers). He's building an S14 with billet RB30 shooting for 2000whp... a race car with a TH400 just like this video. For a road car I just couldn't go this route as the strut has to be almost vertical and the caster is not going to pivot correctly (let alone camber gain). You think the R32 frontend is bad, wait till you put a MacPherson strut on without modeling it all in Solidworks to check geometry. I'm not saying it's a bad way to do it but I'd be really curious to see how it affects the geometry.
    • Hey Christof and welcome!  Sounds like an awesome project! I'm not sure many of the regular users on here would know much about the HK but I could be wrong.  Looking forward to updates.
    • As long as its NOT a HyperSHITtune, youll be fine.
    • First time visitor and currently getting ready to start work on my HK Premier.  Its all stock, 186 with 3 on the tree.  The only mod i have right now is extractors.  I am hoping to get some guidance on slightly modifying the engine to bring a little more power. Just going for a nice, comfortable cruiser.  The car is very straight, however i have been out of the country for 20 years and its been gathering dust at a family farm.  Will be doing quite a bit of body work to cut out some small rust areas (frnt quarter panels and a few other small bits) and fix up the paint.  Will be redoing the interior (its currently black and the seats are in real need of recovering and respringing the driver side (its front bench seat).  The dash needs a little TLC, but no real damage.  As my heater has degraded I am considering fitting something after-market that will be both heater/AC (recommendations here are always welcome). Wanting something discrete that will allow me to use the same controls and not be obvious once inside the car.   For the engine, i have been told i could consider upgrading my cam (imagine i would need a new head as well) and putting a new carby (currently the original stromberg).  However not sure what is going to be the best route.  Would certainly welcome any comments/suggestions.  As  a final step I am looking at changing the wheels. Current hubcaps are in dire need of refurbishment or replacement (imagine its a bit like hens teeth).  Thinking of some clean/classic looking mags (7-inch should be more than enough - not going for a large change in look).  Welcome any comments/advice and of course any questions.
