Buying R34
Originally posted by nismoR34
I am guessing he scammed a higher rating when he 1st took out insurance [like me :D] Or he was listed on his parents insurance during L's...maybe...
This is normal. I bludged 60% ncb off my olds as well but of course, phuqqed it up the wall with my colourful driving record.
T.
https://www.sau.com.au/forums/topic/14059-buying-r34/page/2/#findComment-299468
Kenshin,
>how much the rego? cuz thats the only cost we gotta pay if we >buy from dealer and i know nothin abt it, since this is my first >time buyin a car =( very sad case i know
The dealers usually give you 3 month registration. You do however have to pay stamp duty of 3% of the TOTAL Value of the car to the rta because it is a used car and trading hands. Ie if you buy privately its the same thing hence ppl on the sheet they bought it for $X thousands less to save on this cost.
https://www.sau.com.au/forums/topic/14059-buying-r34/page/2/#findComment-321407
Guest kenshin
what rate will u give regarding to the crime, chances and damages on r34 by some ppl out there
say the rating will be 1-5, the higher the rating is the higher chances and times that have already happened.
cuz i heard that mazda rx7 is seriously targeted by some ppl, whether they intend to steal the car or a part of it or damage it on purpose.
https://www.sau.com.au/forums/topic/14059-buying-r34/page/2/#findComment-340800
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
