Has anyone made a custom exhaust for their car? I have planned what i want to make for mine, and i want to know if i can exclude the cat convertor, the South African R31's dont have cats, and they have more power due to this, so... i dont care for legality really, the permits will come later, i want to do the work while i can over Easter. Any help would be much appreciated.
Thanks
Nate =o)
https://www.sau.com.au/forums/topic/14061-custom-exhausts/
My oh my... must be something with newer cars then, i dunno what the hell a cat does, cep for make it lose power, and filter more crap thru, but its worth keepin it on there then. I made a very nice setup for my old 202 a while back with two - piece extractors joining to one with a single muffler before the diff curve, and a big hotdog at the back. Fully ricey, but the 202 was worked, so i didnt really care. :) 17" rims too...NOO!!! I Miss em :'(
https://www.sau.com.au/forums/topic/14061-custom-exhausts/#findComment-282580
Yea, it doesnt say you have to have a cat, just that u have to comply with emission laws, and that the exhaust shouldnt exceed the volume of the std one by a noticeable amount... I dont know how some cars get over the pits... Ive done nearly all my work to my car this holidays :D Gotta get the permits now before i can drive it anywhere though :D
https://www.sau.com.au/forums/topic/14061-custom-exhausts/#findComment-286079
Nate - a cat converts the exhaust fumes from being very poisonous to be being less harmful fumes. It reduces the carbon monoxide and hydrocarbons from being "emitted" from your exhaust. I think it is mainly for the environment. wow I remembered something from chemistry hahaha
https://www.sau.com.au/forums/topic/14061-custom-exhausts/#findComment-286149
whats wrong with your curren kakimoto catback? i'd only replace it with a custom, if it was less than 3" or rusted out. if you're lookin for a full custom system, its gonna be $1000 at least. if you want to get the rest of the exhaust done (cat - turbo) just get that custom made, should be well under $400. custom exhaust just means its custom made, to how u want it, not an off-the-shelf item.
https://www.sau.com.au/forums/topic/14061-custom-exhausts/#findComment-286281
bad idea.
If it aint broke don't fix it. Get the dump/front pipe done in stainless (should cost you no more than $450 for both fitted).
If you are evil, then have the old cat removed and stick a matchng 3 inch stainless pipe through the middle of it, so it looks like a fully functional cat from the outside.
BTW, the cat stops working once you use fuel additives (like toluene) and run non-factory fuel mistures. They die remarkably quickly on performance vehicles.
https://www.sau.com.au/forums/topic/14061-custom-exhausts/#findComment-286296
Oh well, i dunno about the cat, but im fitting a custom exhaust, cat back...and so far... ive spent... $45 on 2.5" and 3" piping. :O But this is cost price, as im doing all the labour myself. Also, im getting the bends done at my dads work, they use an oxy torch or somethin the rather, with sand or something in the pipe.. to bend it and keep the same diameter right the way thru! Dunno how mandrel bends work, but this is basically the same thing, (maybe is :) iunno)
https://www.sau.com.au/forums/topic/14061-custom-exhausts/#findComment-286373
Also, another good thing, is that marlows is asking for $40 for the adapter that goes between the air pod and the air flow meter. The bad thing with the marlows one, is the intake is SQUARE!!! This reduces the flow of the intake, because the square is smaller than the circular channel. Im gettin this done for nothin too :) just a plate with 3" exhaust pipe stuck on it. EZ! Next problem... heat shield...
https://www.sau.com.au/forums/topic/14061-custom-exhausts/#findComment-286380
But then you run into droning issues when driving which will get pretty irritating. I have a kakimoto myself and they flow really well...thats all u need, if u want more noise just ditch the turbo-cat assembly, get a new dump and screamer pipe made up and ur set dude.
https://www.sau.com.au/forums/topic/14061-custom-exhausts/#findComment-289382
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
