SHORT ANSWER = NO
LONG ANSWER =
I should start by saying... the inputs are NTSC for TV and dont pick up aussie tv except channel 7.. and then its scrambled cos of the NTSC versus PAL. Second Xanavi do not manufacture any maps at all for australia so you will be lost in japan somewhere.
after pulling everything out of mine.. i realised there is an INPUT in the boot.
It is RCA... but the assumption is it has to be NTSC signal.
So an option you have is....
put a carputer in the boot and RCA output from that into the boot input.
then switch the system to VTR1 or VTR2... cant remember which.. the input on the front of the navigation system is vtr1 i think..
anyways whichever input gives you picture is the one you want.
that way you can use the factory screen with a touchpad or something and use it for everything a carputer can offer like GPS/divx/mp3 etc..
Only drawback is you will be using the factory stereo for audio as the navigation etc all pipes in through the factory decks AUX input.
You could use some line level converters etc as found on the CAA forums to add amplifiers and still have a decent sounding setup.
OR
You can remove everything and try to fit another screen into the factory console area, but you will lose the motorised flip up.
but this way you wont need NTSC signals just use normal PAL. and thenyou can replace your headunit etc etc..
For all the costs.. i would look at car computers as a means of using the double din space under the navigation system for a nice touchscreen.
Also if you choose to remove the screen and want a double din space you need the climate control from an r34 with the triple gauges and the double din surround etc..
well i hope this is detailed enough...
enjoy..
If you are talking about the GTR MFD (multi funtion display), possible to put Video in, then you use the stero for the sound.
At Suncoast Rustproofing we offer that service, we install tv tuner and the RCA jack
Thanks for all the help guys!! just one last thing.... do you know how much aprox will all this cost? and is it worth it? I prob woudln't care so much about the nav/gps but i wouldn't mind having the tv/video functions to work. i don't want to buy a car with the special features that don't work! If i do buy the car (i live in brisbane) where should i take it for the work to be done???
I'm looking for a 4 door turbo (gtt). Don't care if it's manual or auto. What do the 3 gauges read? Are they your cars on the pics? Sweet rides! If you don't mind me asking... how much did you pay for your 4 door? and what have you done to it? i notice the body kit, did that come with the car?
the 3 gauges read boost, voltmeter and oil temp. Thanks yeah the 4dr is mine, the kit is a factory option tht came with the car. Haven't done much power wise. Apexi catback, wheels, eyelids and bonnet lip :yucky: Got it for around 30k a year and half ago...u should be able to find a similar model for around 25k nowadays...mine is a 99 model tiptronic auto.
My car will be up for sale soon. 2001 R34GTX-T. The rarer of the models. PM if you are interested!!
if you want to persist with teh screen idea - see me..
x5??? you mean BMW x5????
I can tell you anything you need to know on bmw's and specially on x5's as i work on bmw's for a living! I just wish i had the money to afford one! that'll be a nice upgrade if you do go down that track!
Sorry to hijack. Yeah, BMW X5. Any known problems with the Turbo Diesel 2004 - 05 models??
Try to stay away from the first diesel x5's.... Nothing wrong with them but lots of turbo lag and engine's kinda noisy for a diesel. If you don't mind those things then go for it! They have lots of torque... the latest (05> New engine) has more power, less lag! I would say they would almost keep up with the 4.4 V8. The x5 family are actually the ones with the least problems from the bmw range. Oh yeah.... If you ever go and test one and notice slow crank when first started it's not the batt... it's the starter motor. Make sure it's been replace only if it has that problem... only 50% of the ones i've worked on have had that problem and yes it should be covered by warranty if it's within 2-3year old!
Thanks for the headsup. Much appreciated.
Cheers
Pete
  • 2 months later...
ah ok..
i opened up the inside of my one and make it work without the deck using different switch i took of the screen aswell so its empty casing and put my gps inside..
i think you can get screen bout the same size and put into the empty casing..
    • If you ask just me you'll get 3 different answers.
    • Do not ever trust ChatGPT with anything math related. They can't do math. They have no idea what it is. With enough data we can fit a decent equation in Excel, or if the available fits in Excel aren't good enough, a Matlab clone.
    • You could check/calibrate that with a thermometer, we have long glass thermometers at work which go from -10 to +150°c, they are pretty cheap too I believe,  as monkey fisted soldiers tend to break them, and getting new ones don't seem to send red flags to the people that hold the purse strings Edit: after a google they apparently cost about $80, but, digital ones seem to be much cheaper at around $40
    • I should have prefaced all of this with "I'd really like to not pull anything out of the car for this"
    • Me, I would happly spend some more coin on better tyres for my street car  Will they work, yes, of course, but why substitute some dry grip/braking distance, and wet weather grip/braking distance on what is really old tech to save some coin on your "precious" street car In the end it might not be you that farks up, it's the thousands of other idiots on the street that you need to worry about  For a street car that gets some "fun time", I have found that a quality tyre that can handle dry, wet, cold (Canberra gets pretty cold) and hot conditions, which may costs a little more, is great insurance  From my experience with them (driving around Goulburn in the winter) the RE003's are pretty poor in cold and/or wet conditions on the street If RS4's didn't hate gripping in the cold I would be running them always on the street,  great in the dry, OK in the wet, but, they do hate the cold, with a passion, I run PS5's year round now, basically, I've found the PS5 to be a great year round street tyre for all conditions, they last well, and are mid range pricing wise TL;DR. Tyre choice is probably like what brand and grade oil you should use, ask 10 people, and get 10 different answers... LOL
