just like to thank who ever runs these forums. thanks to you and the members of skylines australia i dont have to sell my car to buy a work car. Can you beleive you can get roof racks on a skyline! im over the moon about keepin my car, just think i could have been drivin a van! :happy: tried researching about roof racks found nothin. searched on here and wha la :sorcerer: roof carrier systems in camberwell. (cheers jamezilla) keep up the good work. Skyline electrics? hmm.... maybe good enough for cashies on the weekend till then. :D
So do they just hook on to the window sills? How much if you dont mind me asking? are they easily removable?
Always thought about roof racks for my line. Its pretty ridiculous going surfing with 2 boards across the passenger seat and my mate sitting behind me in the driver side rear seat.
lol yeah i found it in the garage i was reading a thread about gayest mods and was gonna put a picture of the disco ball in. forgot to take that out before the shot. well done spoting that.
the cost? oh you wouldnt beleive out of all the places that would have a second hand set for a 33 i happened to go to them. i paid $275 new they were gonna be $420 i think.
rolla racks or rhino do this cost around $600 i think from memory i have been looking into this for my surfboard...
Yes hook on the sills then extended out onto the roof with a rubber support.
must be rola rack that do them. rhino replied to an email i sent them saying they do one but its not fully removable. still waitin on responce from rola but oh well too late. its actually an off the shelf kit made in germany. they must have a few skylines over there i guess. speciffically made for 33's
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
