I can do it, but I don't have a wideband so I can only remove boost cut, move the rev limiter and whatnot. Anything with fuel maps is kind of risk without a way to check it.
IIRC Hyperdrive charge about $700 for a full tune using the stock ECU
http://www.speedworks.com.au/products/bikirom/bikimain.html
speed works do it for $1350 lol, they add a circuit board inside your ecu and retune it, have a read of the web link, gives ya all the info :(
ouch.. $1350's pretty steep.. wanted to avoid outlaying for a pfc because I'll probably upgrade engines at some point. Would you be able to send your rb20 pfc back to AP Engineering to have them convert it back to rb25?
Most tuning shops in Wa will be able to setup an R33 RB25 PFC etc into an R32 RB20 giving you the option to use it on an RB25 later.
