Wow, indeed.
I wonder, how much all that extra parts costed...
The wider rear panel and the lower front lip... V-spec
Wouldn't be genuine parts?
Someone had a set of rims a few weeks ago like what your wanting.
https://www.sau.com.au/forums/topic/140678-r34-gtr-rims/#findComment-2622783
They look like they could be the standard colour, just in shade/different light.
Maybe you'd be best buying some that have a few marks, get them cheap, fix them up and paint them the colour you want?
https://www.sau.com.au/forums/topic/140678-r34-gtr-rims/#findComment-2623336
Yeah theres.. two colours for stock R34 GT-R Rims...
I've got a set of Silver ones and the Darker shaded ones. Sorry not for sale. Just letting you know.
Satanic: Disagree haha... Bonnet i don't like...GT-R's need that bottom lip to finish it off else it looks to high personally or GT-Ts actually..
https://www.sau.com.au/forums/topic/140678-r34-gtr-rims/#findComment-2627191
I think you will find someone painted them silver .
https://www.sau.com.au/forums/topic/140678-r34-gtr-rims/#findComment-2627478
the lighter silver R34 wheels are off the NUR spec i think... good luck finding original ones of these... all others are the dark grey...
the lighter ones look like this:
The lighter (silver) rims were fitted to the Midnight Purple 3 limited edition R34 GTR's. Very hard to come by.
Cheers
Jo
https://www.sau.com.au/forums/topic/140678-r34-gtr-rims/#findComment-2632782
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
