  • 4 weeks later...
yo just moved to the sunny coast, near kawana waters... lots of old people here, where are all the chicks?!?
wanted a R32 but coundlt find a decent one for my pric range
just bought a Soarer today, drives like a beauty all it needs is rims and stero and its pimpin :P
does the SAU club allow non skylines? need to take this puppy out for some testing once i get it insured...
Arrive on the coast on Monday :P Car won't be too far behind I hope, need to see some of the area.
Welcome to the coast guys! What type of soarer do you get TJ?
Maybe we should have a sunny coast cruise?
