i want mcdonalds so bad right now, but mr. skyline is annoying me and i dont want to drive.
anyone wanna bring a large mc chicken meal with no mayo and coke as the drink to buderim? Ill buy you sex.
Hahaha thats the funniest shit, shame darrel doesnt think so, i swear he tried to hit on all the guys at kimbos that night, fagwa
anyone on here know alex from pomona? (nismo boy he was out that night that my mate hit the pole) he drives.... drove a green ED falcon. this morning he was on his way to work and decided to do a skid out the front of his work. he was coming round a corner and did something to get it sideway, and then got all crossed up and ended up hitting a council bin, 2 sign posts and an awning of the take-away shop opposite his work.
smart way to show your boss how responsible & mature you are......rofl
Yeah i know alex, he works at pages, thats no good, atleast he didnt hit a gutter again
gee thanks for the hot tip... thought some one might know of some one, or has one and never botherd to try sell it....
http://www.calaisturbo.com.au for you buddy
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
