The Sunny Coast Chat Post
Baysidebluebnr34
lol key board warriors are back lol.
u RBs spun a big end yet.
Cracked your weak as piss alloy block yet or had to resleeve your oval bores?
Oh wait, that's right......you have to make more than 300 hp for that to happen.
Charge up Marky!
Charge up Marky!
lol dan... u need more than 500 to break the SR block lol. come on dan u should knw that.
still waiting on some more moolah before i see 270kw :turned:
still waiting on some more moolah before i see 270kw :w00t:
nah u cant spin a big end in an sr, :turned: well how come a mate of mine did it with a stock s14 then?? answer me that?? all u have to do with any motor is rev it hard enough for a long enough period of time. lol
all you skyline users are loosers. get real cars.
Your not that bloke with the non turbo Pulsar are you? Think we met you at Matilda one night...
If so, i wouldnt be running your mouth because you cant beat Skylines...
And for your information, Ryda's old r33 (which he has now sold) used to keep up with Turbo Skylines.
Chris
still waiting on some more moolah before i see 270kw :whistling:
it was all about 240rwkw the other day
funny now that i told you that 270rwkw would be required to match a 300rwkw R33 on power to weight that the goal posts changed ha ha
LMAO doesnt take much hey,,,
well considering you have a r33 which is NON turbo ill let u have about 20-25 car lenghs headstart :whistling:
hahahaha firstly if u were actuallly apart of the sunshine coast post u would have seen that i sold my N/A and purchasin a R34 GT-T.. and if u could read properly i was talkin bout my rc car beatin ur s15 :P...
Chris
Lets see, the cars I can remember SR_PWR having, and I've had a ride in every one are, white 180sx (TD 06-20G turbo'd), another 180sx , white r32 gtst, white r33 gtst (200kw?), 600hp red series 5 rx7, silver s15 200sx, gun metal r32 gtr, some poxy 4wd, ohh 300kw rb25 silva, orange 180sx (180kw?) and current is a 180sx.. though i haven't been in that one but i'd say it's be around 230+ rwkw..
took ird46 in the whtie 180sx over 200power runs at over 600hp and a few 10sec quarters to crack the block. for a 4cyl 2litre stock bore thats alright i thikn lol....
very good indeed.. :P
nah u cant spin a big end in an sr, :nyaanyaa: well how come a mate of mine did it with a stock s14 then?? answer me that?? all u have to do with any motor is rev it hard enough for a long enough period of time. lol
lol.. so..? ive seen standard ZZE toyota engines do it too lol. so..? perhaps the SR had a tough life or bad oil.?
yes i said 240 i didnt say i need 270kw did i.. andy put ur glasses on im just saying i should push my std bottom end to 270kw just cause i can and have a spare. jumping to conclusions.. tsk tsk lets hug :sorcerer:
Oh ok...Well i have to wrong person and apologise if anyone took offence to my comment/s.
Thanks Dyna.
Chris
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
