im still droolen hahahah...
nah i gotta find out what is up with the turbo, still doesnt make anything more than 1 or 3 psi at max.. if anything at all.. after that. boost controler to 8psi and she'll be fine with a fuel pump.. then start on the inside mess.
till a tune
then 15psi daily and 19psi on high boost
till a tune
Checked your cat converter? It could be blocked,
I was boosting back to 3-4 psi barely until I realised I had blown my cat :)
brand new highflow cat... doesnt matter now
dump pipe came off last nite and boost spiked.... sent me a 180 into a rock wall and its f**ked.... bye bye r31 coupe *CRIES*
anyone wanna buy some parts off it.... kinda f**king devo'd
SSSSSSHHHHHHHHIIIIIIITTTTTTTTTT mate.
There goes 1+yrs of blood sweat and tears down the drain.
I can't believe it :D. Never thought you would smash a car.
Buy a cheap s13 shell and dump the box and motor into that :D
hey guys im from sunny coast and drivin a r31 nissan skyline wagon Gx 88 cream in colour wave if ya see me drivin through mdore. peace.
Lol did my partner open that gate on you and another blue r31 on maroochydore road? If so tidy 31 champ!
yeah it was a hot as f**k car.. i loved it, over 3 years of wadges and 2 cars got me there... till the dump pipe came off the turbo and boost spiked... hello wall..
cant think of another 31 atm... 4wd' to get, then i can get a track only car
welcome to the coast mate, prob seen my red now heap of scrap metal cruisen around? if you want some 31 parts hit me up, or
www.r31skylineclub.com will get you the into you need
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
