Hey Chris,
What roads have you come up with? The main ones along the top of the range are quite boring and on a weekend run will end up with most doing 40kph due to tourists dribbling along there. Very interested to see what roads you have found. :D
Cheers, Chris.
Edited by PHT33
DATE:
19th June 2011 (its a sunday!!)
WHERE TO MEET (sunny coast people)
BEERWAH HOTEL
53 BEERWAH PARADE
BEERWAH
11 AM FOR A 1130 LEAVE.
WHERE TO MEET (Brissy people)
BP CABOOLTURE - (TWIN BP's) NTH BOUND
BRUCE HWY
CABOOLTURE
1000 FOR A 1030 LEAVE
WHERE ARE WE GOING??
this will take in beerwah, peachchester , Bald Knob , Maleny , Balmoral Ridge , Montville and finally lunch at the palmwoods pub.
be there.
route is :
peachester rd- up range- right turn at bald knob rd -> end - left turn up to maleny - rt turn at montville rd break point at the look out and oward from there...
that is a teaser. I'll finish it on the day.
  • 1 month later...
hey people!
Theres a import meet this saturday night at 7:30 at the caloundra bus depo
ive heard there is gunna be alot of different cars there if anyones interested ,im going down in a grey ceffy , i think there going on a cruise at 9? not sure where? but yeah if ya board its somthing to do ....
window wont move at all, ive got to push/pull it by hand to get it to move
you could do some tests to see if its the regulator or the motor or relay or the switch ,if it sounds like the motor is working then your reg is probly stuffed but if no noise then pull your door trim off and
try direct power to the motor of the window (use a battery and 2 wires ) swap them from pos to neg for up and down etc ,if window goes up and down then your window reg motor is ok , if not then start with a new motor ....
if motor is ok id then move to the relay box they always stuff up ,i got a blown one the r/h/r door on my cefiro i found t hat was bugged cos i swapped it for the other side one and it worked but if you have r33 2 door you will need to get one off an other car cos it runs the other door too, if thats ok then try an other switch . Other wise an auto electrition could find the prob but will prob cos $75+ just to find the problem .
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
    • We have an alignment shop out here that does what you're talking about but he wants like 800 AUD a pop. DIY is "cheaper" but once you start accounting for the value of your time I'm not sure it's worth it.
    • The main catch phrase for any car is "the eye of the beholder", and "personal tastes and preferences" And as for the plastic "flares", I honestly think they look cheap and tacky, and I cannot see them aging well, maybe if they were body colour they might look better to my eyes, but, I would still prefer it the were more like the older WRX STI models that had the wider body metal panels In saying all this 5hit, I wouldn't buy a new WRX again, even if it had the wide body metal panels
