yep. gotta go do some actual work now though which is kinda strange. we're cleanin out an old storeroom that has like 10yr old computers n printers n stuff in it. tip run in the work ute
A group of us are going to meet at the chancellor park woolies at 7:20 for a 7:45 departure to the main meet for the SCC if anyone else wants to join us, if you let me know your comin either pm me and i will give you my number or just indicate in this thread that your keen so we can get a rough idea of numbers so we dont leave with out you as we did last year
Hey,
Just wondering what this cruise is???? Where abouts is it and what day/time etc... Might be interested.
Thanks.
Chris
Edited by SunnyCoast
wes get home and start puttin that car together.
Cars all done, just gota get the window tint done on thursday and put the interior bits back in but the ignition is now all sorted out and the new window is in, big thanks to the big rice man and sir 4door for all ur help and fluids couldnt have done it with out ya's
spewin u cant make it chris it will be an awesome day
See u at the meet shaun
sorry for the interuption, but i come bearing a message...
http://www.skylinesaustralia.com/forums/Sc...rs-t194583.html
Ok to keep certain people happy we will be leaving the sunnycoast meeting spot a little earlier. so instead of leaving at 7:45 we will now leave at 7:30 so youd wanna be there around 7:15ish.
Its great to see a quite a few people are comin from the coast
ok ill be at the meet point too.
Cyas there
Blink... I got a missed call from you at like 1am in the morning a couple of nights ago...whats with that?
Also, i thought you hated cruises?
So ghey..I live like 1 min away from the meeting point..So devo'd that i cant go.
Would you boyz (and girlz) be up for organising a Sunshine Coast cruise? I would be up.
Chris
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
