Blink... I got a missed call from you at like 1am in the morning a couple of nights ago...whats with that?
Also, i thought you hated cruises?
So ghey..I live like 1 min away from the meeting point..So devo'd that i cant go.
Would you boyz (and girlz) be up for organising a Sunshine Coast cruise? I would be up.
Chris
Chris i dont know bout everyone else but id be more interested in a dinner cruise or go 10 pin bowling followed by a cruise or sumthin along those lines. But im sure we can organise sumthin. just let me know what you come up with and give me as much notice as possible so i can actually make it (try keep in sunday arvo or sat/fri nitesif possible)
Wes
haha thanks for the offers guys, especially a ride in that 180 -whoo-, but wont be able to go. got a lot of shit going on.
+ a few mates are going on a hill run. am more interested in that than driving down to brissie ;):(
Edited by r33cruiser
(I) say NO. it doesnt obstruct vision, but may be a head impact issue.
i had a 5" tacho mounted in my a-pillar in my old s13, got pulled up by the popo, and they said it was FINE.
*plus ive been pulled over a few times with mine, and no popo has said squat, even when being pulled over at 2am, with 2 defi gauges blaring in my face :)
Chris
1am?? Hmmm I must have rang the wrong Chris then, my bad sorry.
I'll go to properly organised cruise with a cause (fundraising) - not weekend lapping :laughing-smiley-014:
gauges have to sit under the steering wheel to be legal.
Correct. Pillar Pods are illegal because "line of sight" "visual distraction" laws in QLD.
I have now mounted everything that illuminates bright light, such as Turbo Timer, Gauges below the steering wheel. Hey..It mightn't look as good to your friends...but it saves your a$$ from getting defects and having to pay for more donuts.
*plus ive been pulled over a few times with mine, and no popo has said squat, even when being pulled over at 2am, with 2 defi gauges blaring in my face :D
mmm....Brad has a point though....i think its up to the individual when they pull you over....Brad usually isnt a smart a$$ to them so perhaps thats why they tend to overlook it.
thats about right man. u can expect to pay around $400 for a "good" intercooler, and about $200 for the piping.
but what u can do is buy the piping kit off ebay. they're not too bad, and just wack in a good intercooler :rofl:
i highly recommend monkey warehouse:http://www.monkeywarehouse.com.au/
http://www.monkeywarehouse.com.au/09mcooler.htm
i got an ebay kit, but im only using about half a metre as i have a forward plenum, and none of the piping is in the engine bay..bar 20cm, so its REALLY good with heat. replaced the fmic, sold it on boostcruising, and used the cash to buy a monkey warehouse fmic.
it is really good.
Anyone seen some of the specials on Modyourcar website?
http://www.modyourcar.com.au/hybrid-gtspec...t-rb25det-p4227
How do they compare to other places?
they look expensive. i've seen Apexi SAFC Neo for $150 - $200 cheaper
hi guys. for some reason i only just found the link to my line on the elite dyno day a month ago. here it is
http://au.youtube.com/watch?v=7S7nd3QusxM
MAKE SURE YOUR VOLUME IS AT MAX, TO EXPERIENCE IT PROPERLY
also this sunday, im aiming to wack in my plenum
Your screamer is insane!!!!! Sounds nicer on the street. :rofl:
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
