Thank you my friend. Its hard to make sure you dont encourage the bubbles when your rushed....
eyelids look mad man, glad u like em.
+ not to mention they will give u like 20kw*!!!!!
*kw=kiler wasps
anyone know much about hicas?
like a reason why my hicas light would be on and that i have lost all power steering?
anything would help....
Because it's buggered, common problem.
Search it in the steering and suspension forum and you'll find plenty of howto's. Easiest way for memory is to buy a hicas lockbar and just not have it. It's more of a pain in the ass than anything.
Does anyone that lives or drives around the Noosa area regularly, want to do me a small favour?
I just need some information which should be relatively easy to get.
It is quite important, otherwise I wouldn't be asking here.
PM for details. Will give a small thank you for information.
LOL daz. i woudlnt mind one of those!!! i thought you both would be glad that it wont be on the coast anymore, 1 less car you wont stress about beating you :cool::D :D :P
already got my new car it cost me 1500 so wach out!
MY IMPORT DAYS ARE OVER....................................until further notice
why did i see your car yesterday arvo driving then if its off the coast?
so your new ride is a VX clubby is it? they go for about $1500 now days dont they lol gotta love australian car values.
:banana:
Bugger aye adam got rid of the 180?
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
