how could i forget :banana:
on another topic. spotted a few liners out saterday arvo.
was a bluish green gtst with a gtr rear wing with a rooted engine. blowing shitloads of BLUE SMOKE mate..lol atleast u thought u looked cool tho. nice pose
Edited by r33cruiser
Stewie man.. jus throwin this out there cause i heard it.. but u datin allara?
no mitch, i am not. don't know where u heard it.
brad;
1. u had an intercooler, FPR, and fuel pump over me for starters, and secondly just because i can be
Edited by SoarerGT-T Cruiser
lol dude u had fmic, big dump, zorst, and like 20psi. and u only made like 230hp at barnes :S....and u dont need a fuel pump yet. so that is irrelevant, and so is the fpr, stock pressure :D
still less than the 256 i made over a yr ago on 10pound
and brad, yeah, i was running 13psi, and barnes didn't have the cooling fan on. dude, even u should know that they invented intercoolers to cool the air whilst the car is driving. i might as well have had a straight pipe running from the turbo to the inlet
B r a d.....ditch ur plates....
I hear an earthquake coming.....
AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
Isnt intercoolers jus to make ur car look super dooper fast?
Edited by Darkness_Ryda1
hahah mitch u funny (unt.
anyways, andrew funny story.
this shud help u out
http://soarercentral.com/cgi-bin/sc-forum/discus.cgi
unfortunately ur plates are attracting the wrong crowd... happens to the best of us..
just not me... or many other people :D....
.................................................ok jus u...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
